1astrokeit Posted March 18, 2011 Share Posted March 18, 2011 Im installing konis with s tech springs. I was curious if I needed any other parts to get it aligned properly. I only running 17s. Nothing dramatic Link to comment Share on other sites More sharing options...
motorbykemike Posted March 18, 2011 Share Posted March 18, 2011 cut the front bump stops in 1/2 & trim the tops off the rears Link to comment Share on other sites More sharing options...
1astrokeit Posted March 18, 2011 Author Share Posted March 18, 2011 The ones that are in the struts? What you mean trim the rears? Link to comment Share on other sites More sharing options...
motorbykemike Posted March 18, 2011 Share Posted March 18, 2011 on the koni fronts the bump stop that is under the dust boot in the rear it's this big rubber end of missle looking thing bolted to car & the suspension hits it when the car is compressed or to low , like w/ s techs , cut 1/2-3/4" off w/ a hacksaw . you might want a bumpsteer kit going that low as well , see whiteline rock kit Link to comment Share on other sites More sharing options...
1astrokeit Posted March 18, 2011 Author Share Posted March 18, 2011 Does it matter on the rear which end of the bump stop I cut off? And the fronts I cut in half correct? Link to comment Share on other sites More sharing options...
motorbykemike Posted March 18, 2011 Share Posted March 18, 2011 you can only cut the "exposed" end on rear , other end bolts to the car . front , 1/2 but make sure you use the end that fits the strut rod tighter . rce makes shorter & stiffer fr stops , you may want t o check them out , there may even be a group buy going on right now . Link to comment Share on other sites More sharing options...
1astrokeit Posted March 20, 2011 Author Share Posted March 20, 2011 When purchasing the thw bump steer kit, should I just buy the replacement tie rods or should I get th e kit. Im tryin to keep the cost down a bit. Link to comment Share on other sites More sharing options...
AZP Installs Posted March 23, 2011 Share Posted March 23, 2011 You really want the whole kit. It works together. -mike http://www.pbase.com/paisan/image/91072632.jpg AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
1astrokeit Posted March 25, 2011 Author Share Posted March 25, 2011 Is that all I need to get it aligned? Dont need nething for the rears? Link to comment Share on other sites More sharing options...
1astrokeit Posted March 25, 2011 Author Share Posted March 25, 2011 I dont need shims for the rear will I? Link to comment Share on other sites More sharing options...
1astrokeit Posted March 25, 2011 Author Share Posted March 25, 2011 When cutting the bump stops for the front, which end does the cut part face? Im assuming the cut part faces the strut? If anyone has a pic of a cut bump stop that they did please post. Link to comment Share on other sites More sharing options...
