SlickSpur Posted June 23, 2011 Share Posted June 23, 2011 Will this fit? I'm looking at some 18" Superleggeras. I have the Eibach Pro Kit on my car, factory struts. The seller says the wheels are 18x8 with a +51 offset. Will I need to roll my fenders or anything? I'd really prefer to buy wheels that don't require modification. Link to comment Share on other sites More sharing options...
W1CKED Posted June 24, 2011 Share Posted June 24, 2011 What are the tire specs? WillTheyFit.com Link to comment Share on other sites More sharing options...
SlickSpur Posted June 24, 2011 Author Share Posted June 24, 2011 Whoops, they're 215/45/18 RE92a's. Not sure how to read this http://www.willtheyfit.com/wheelimage.php?tyrediameter=625.3&tyrewidth=215&tyrecirc=1964.437884045&wheelwidth=177.8&wheeldia=431.8&offset=55&poke=33.9&inset=143.9&aspect=45&tyrediameter2=650.7&tyrewidth2=215&tyrecirc2=2044.234337355&wheelwidth2=203.2&wheeldia2=457.2&offset2=51&poke2=50.6&inset2=152.6&aspect2=45 Old New Diameter 625.3mm 650.7mm Circumference 1964.4mm 2044.2mm Poke 33.9mm 50.6mm Inset 143.9mm 152.6mm Speedo error 0% -3.9% Reading at 30mph 30mph 28.83mph Reading at 60mph 60mph 57.66mph Ride height gain 0mm 12.7mm Arch gap loss 0mm 12.7mm Link to comment Share on other sites More sharing options...
whitetiger Posted June 24, 2011 Share Posted June 24, 2011 you should be fine, though if your stock tire is 215/45/17, you would be better off with a 225/40/18 tire, or even a 245/35/18 tire. Link to comment Share on other sites More sharing options...
SlickSpur Posted June 24, 2011 Author Share Posted June 24, 2011 I believe 215/45/17 is the stock re92 size. I pulled it from the FAQ sticky thread. The tire size is the ones that are on them now, I was looking at buying these used from a local seller. I think there isn't much tread left on the tires, so I could certainly go for something thinner walled but I'd be stuck with the ones on it for a few months. Link to comment Share on other sites More sharing options...
Spec B Posted June 24, 2011 Share Posted June 24, 2011 I had these same exact 18X8 Superleggeras..they fit perfectly, even slammed on coilovers. They will not clear Brembo's tho..you will need a 3-4 mm spacer. Link to comment Share on other sites More sharing options...
Spec B Posted June 24, 2011 Share Posted June 24, 2011 I had it on 225/40's btw. Link to comment Share on other sites More sharing options...
whitetiger Posted June 24, 2011 Share Posted June 24, 2011 fyi, i ran 245/35/18 r-comp tires(usually come wider then standard tires of the same size) on a +51 ssr rim with coilovers. it cleared the inside and cleared the unrolled fender on the outside. Link to comment Share on other sites More sharing options...
Drew888 Posted June 28, 2011 Share Posted June 28, 2011 ^^^245/35/18's on a +51 seems perfect. What are you using now? [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
SlickSpur Posted June 28, 2011 Author Share Posted June 28, 2011 245/35/18's on a +51 seems perfect. What are you using now? The tires on the wheels are 215/45/18 RE92as, not 245/35/18s, that's why I'm curious on the fit (especially lowered on Eibachs). I'm using the stock 17"s with the stock RE92s right now (215/45/17) Link to comment Share on other sites More sharing options...
lil_z_33 Posted June 28, 2011 Share Posted June 28, 2011 fyi, i ran 245/35/18 r-comp tires(usually come wider then standard tires of the same size) on a +51 ssr rim with coilovers. it cleared the inside and cleared the unrolled fender on the outside. what was the width on this rim? what are your thoughts on 18x8.5 +48 offset, with 255/35/18. coilovers and rolled fenders, fronts are pulled as well... Link to comment Share on other sites More sharing options...
