ivonr Posted September 20, 2013 Share Posted September 20, 2013 Did anyone actually do this? I'm @ 55k and I'm wondering if its time..ride is getting a little rougher and she's seen some off-roading. Link to comment Share on other sites More sharing options...
xxirish83x Posted September 20, 2013 Share Posted September 20, 2013 I just did my fronts at 95k. Pull the boot back on them and see if they are leaking. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted September 20, 2013 Share Posted September 20, 2013 I did but mine sat for 4 years and it's 8years old Link to comment Share on other sites More sharing options...
c-lo Posted September 20, 2013 Share Posted September 20, 2013 236k. still on my original fronts. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
bluesuby Posted September 20, 2013 Share Posted September 20, 2013 I changed all 4 at 70k and got a much better ride. If you're going with a good quality strut like Koni you may as well get the most out of them for as long as possible. Link to comment Share on other sites More sharing options...
DiscoPete Posted September 22, 2013 Share Posted September 22, 2013 I changed all four struts in my OBXT near 37K miles. The LR had begun to leak oil, and the car always did have too soft and bouncy of a ride so I took the oportunity to upgrade to stiffer struts. It now rides better than it ever did before. Link to comment Share on other sites More sharing options...
rob-2 Posted September 22, 2013 Share Posted September 22, 2013 Still original struts for me at 103K. I've got no signs of blown struts. Link to comment Share on other sites More sharing options...
GTPpilot Posted September 23, 2013 Share Posted September 23, 2013 110k on my (as far as I know) original suspension. No leaks, handles fine. I don't plan on replacing unless I absolutely have to. Seems like suspension bushings and stuff fail before the struts actually fail. Link to comment Share on other sites More sharing options...
Danteneon Posted September 23, 2013 Share Posted September 23, 2013 Replaced/upgraded mine at 69K. While they weren't badly worn or leaking, they are still just stock OBK struts. Replaced with SpecB units and couldn't be happier. I like to cook my pets and my family. Use commas. Don't be a psycho. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted September 23, 2013 Share Posted September 23, 2013 replaced the rears at 98K before buying it, replaced the fronts around 110k. Next time I'll probably do the springs and other shizzle too. Link to comment Share on other sites More sharing options...
lockmedic Posted September 23, 2013 Share Posted September 23, 2013 I bought a set of used struts from a 2005 LGT wagon that allegedly had 60k on them. Both were leaking slightly (or had some really tough Cosmoline transit coating on them) and one had no rebound. . . so yeah, I don't see a problem replacing them at that mileage. Top hat bearings were crunchy too. . . Link to comment Share on other sites More sharing options...
