mike2225 Posted May 12, 2012 Share Posted May 12, 2012 Im having issues with my lug nuts keep coming loose and ill get really bad vibration coming from both front wheels.Ill tighten my lug nuts as tight as i can and ever couple of days my front wheels will vibrate really bad..anyone have any idea why this is happening?? Link to comment Share on other sites More sharing options...
rens914 Posted May 12, 2012 Share Posted May 12, 2012 do you have original subaru rims fitted. if not, do you have the correct centre-rings fitted. it seems to me youre rims aren't correctly centerd. rens Link to comment Share on other sites More sharing options...
charlie_sheen Posted May 12, 2012 Share Posted May 12, 2012 are your rotors warped? Link to comment Share on other sites More sharing options...
Dawkness Posted May 12, 2012 Share Posted May 12, 2012 Are your bolt holes tapered? What are you tightening your lugs with? Ratchet? Impact? Breaker bar? Link to comment Share on other sites More sharing options...
vtbimmer Posted May 13, 2012 Share Posted May 13, 2012 Overtightening your lugs can warp your rotors and cause vibration. You should always use a torque wrench and torque wheels to the proper spec. Link to comment Share on other sites More sharing options...
