RobY Posted October 12, 2004 Share Posted October 12, 2004 I saw a device sold in sears called a vaccum brake bleeder tool I was just wondering if anybody has used one of these to bleed brake lines before. It seems like a really good way to avoid some of the fuss involved in doing a good brake bleed. How does it work in comparison to the "have your friend push the pedal while you turn the screw" method. Link to comment Share on other sites More sharing options...
rao Posted October 12, 2004 Share Posted October 12, 2004 Is it the same thing as a Mity-vac? If it is tthey are decent and not too expensive. Reverse bleeders work pretty well also [url]http://www.phxsyss.com/index.htm[/url] I've used both and I still prefer the 2 person free method. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
sspicollo8 Posted October 13, 2004 Share Posted October 13, 2004 Any opinions on these? [url]http://www.fastwrx.com/speedbleeders.html[/url] Link to comment Share on other sites More sharing options...
RobY Posted October 13, 2004 Author Share Posted October 13, 2004 [quote name='rao']Is it the same thing as a Mity-vac? If it is tthey are decent and not too expensive. Reverse bleeders work pretty well also [url]http://www.phxsyss.com/index.htm[/url] I've used both and I still prefer the 2 person free method.[/QUOTE] yeah its the same as the mity vac but the craftsman model seems to look a bit better with brass instead of plastic cylinders Link to comment Share on other sites More sharing options...
Trent Bates Posted October 13, 2004 Share Posted October 13, 2004 [quote name='sspicollo8']Any opinions on these?[/QUOTE] I've got these in my GTP. They work fine. I was having trouble getting the system bled because I was trying to get amateurs to help. These solved that problem! Link to comment Share on other sites More sharing options...
rao Posted October 13, 2004 Share Posted October 13, 2004 I think Mity-Vac makes various models from junk to very high quality. I bet they make the Craftsman one. I have never used speed bleeders, but you can buy them almost anywhere so people seem to like them. They seem like a good idea. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Tide Posted October 13, 2004 Share Posted October 13, 2004 I have a mity vac and have used it to do the brakes on my motorcycle, works pretty well. Basically you'll still need a friend to charge the line, then the vac sucks down the bubbles. If you're only doing it once, skip the vac. If you will do it more often, get the vac. Link to comment Share on other sites More sharing options...
RobY Posted October 13, 2004 Author Share Posted October 13, 2004 [url]http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00921021000[/url] Link to comment Share on other sites More sharing options...
