Helloreaper1 Posted June 10, 2014 Share Posted June 10, 2014 Im having a tough time figuring out if i can use this motor as a direct swap. My ej22 has some internal issues that are slowly getting worse so im looking for a motor with a little more power that would be a direct swap. Just motor, no Ecu or anything. I heard I didnt need an Ecu, that mine would work as long as I dont use a turbocharged motor and as long as I use a phase 2 motor. Please help! Thank you! Sent from my SPH-L710 using Tapatalk Link to comment Share on other sites More sharing options...
Ironcheflove Posted June 10, 2014 Share Posted June 10, 2014 Check out the swap stickies. If you can go from 2.5 to 2.2 with no problems, I don't see how it's not just reverse. Link to comment Share on other sites More sharing options...
Helloreaper1 Posted June 10, 2014 Author Share Posted June 10, 2014 I keep hearing about these "stickies". How do I find them? Im still new to this forum haha Sent from my SPH-L710 using Tapatalk Link to comment Share on other sites More sharing options...
Zues Marine Posted June 10, 2014 Share Posted June 10, 2014 oh, yeah tapatalk hides the stickies by default i think- you have to go into the forum settings and select to show the stickies or go to it on a web browser and they should pop up as the first 6-7 posts Link to comment Share on other sites More sharing options...
johnegg Posted June 10, 2014 Share Posted June 10, 2014 i can't help you with out the year and model of each car. but based on your ej253 reference and the fact this is a second gen discussion, i'm pretty sure the answer is no. but i need more info to be sure. Link to comment Share on other sites More sharing options...
Stevo F Posted June 10, 2014 Share Posted June 10, 2014 I'm guessing the ECU won't work since it's a much newer 2000+ engine you are thinking of swapping in. The EJ25D up thru 1999 should swap in to your car without needing an ECU change. Personally I like the way the EJ253 in my '05 OBS runs compared to my '98 EJ22 so I can understand why you would want to do this swap. Link to comment Share on other sites More sharing options...
Helloreaper1 Posted June 10, 2014 Author Share Posted June 10, 2014 So if I do try to swap the ej253 in I should also get the ecu? Link to comment Share on other sites More sharing options...
johnegg Posted June 10, 2014 Share Posted June 10, 2014 WHAT YEAR? model? trans? miles? color? Link to comment Share on other sites More sharing options...
Helloreaper1 Posted June 11, 2014 Author Share Posted June 11, 2014 Mine is a 1999 subaru legacy 30th ed 2.2 sohc 5mt gold 110k miles Link to comment Share on other sites More sharing options...
johnegg Posted June 11, 2014 Share Posted June 11, 2014 if you swap in an ej253 engine, you will need the ECU and the wire harness if you do not want a CEL and trouble codes. i guess the question is why would you? a 00 ej25 would be MUCH easier , no harness and no ECU needed. just use the intake manifold w/ wires and the cam/ crank sprockets off of your original engine. easy peasy. Link to comment Share on other sites More sharing options...
Helloreaper1 Posted June 11, 2014 Author Share Posted June 11, 2014 Thats what im trying to figure out. I want a ej25 that'd be bolt in. No ecu and junk. Why couldn't I use the sprockets from the ej25? I just need a simple replacement that has a little more power Link to comment Share on other sites More sharing options...
boattlebot Posted June 11, 2014 Share Posted June 11, 2014 While were on the subject, ive had a question in the stickies for a while but times runin out to get this car or not. I have the option to pick up a 2011 sti thats wrecked. Would the motor work in a secound gen? I know the electronics will be tricky but I got that, will the motor actualy bolt in? Link to comment Share on other sites More sharing options...
Helloreaper1 Posted June 11, 2014 Author Share Posted June 11, 2014 Im pretty sure the only sti stuff we can use is from a 04 sti, after that everything changed on them. At least that is what ive heard/seen while researching how to do an sti swap to my legacy Link to comment Share on other sites More sharing options...
Helloreaper1 Posted June 11, 2014 Author Share Posted June 11, 2014 Im also still new to this, so hopefully someone with more experience will chime in haha Link to comment Share on other sites More sharing options...
Zues Marine Posted June 11, 2014 Share Posted June 11, 2014 simply put, that motor will not work, soooooo many differences and modification needed to everything.. many components of the 2004's STi like brakes hubs and wheels, etc. will work because they have the 5x100 hubs, instead of the 5x114.3 that they switched to in 2005+ Link to comment Share on other sites More sharing options...
boattlebot Posted June 11, 2014 Share Posted June 11, 2014 So the motor wont physicly bolt in? Good thing I didnt pull the trigger on it yet Link to comment Share on other sites More sharing options...
twisty Posted June 11, 2014 Share Posted June 11, 2014 anything will bolt in with enough determination and money... Link to comment Share on other sites More sharing options...
Helloreaper1 Posted June 11, 2014 Author Share Posted June 11, 2014 Im looking for direct bolt in. I dont want to spend lots of time and money for a quick swap Link to comment Share on other sites More sharing options...
johnegg Posted June 11, 2014 Share Posted June 11, 2014 look, i don't know what an ej253 is. for some reason i thought it was an 05 engine. but i do not know. but if you own a 99 legacy with an ej22 engine, you can swap in a an ej25 from 00 - 03/4. and as long as you use your original intake manifold and cam / crank sprockets it will run fine. you MAY also have to do an EGR work around depending on if your 99 has EGR and depending on if the donor engine has EGR. 00 - 04, some engines have EGR and some do not. sorry for the confusion, but that is why i always ask for the year of both cars / engines. Link to comment Share on other sites More sharing options...
Helloreaper1 Posted June 11, 2014 Author Share Posted June 11, 2014 Ah, I dont know anything about the ej253 I was just looking for a phase 2 motor that was a 2.5 That is one of the few that came up Link to comment Share on other sites More sharing options...
86bratman Posted June 13, 2014 Share Posted June 13, 2014 Swap your ej222 timing gears and intake manifold and drop it in. Only difference I've seen between a 251 and 253 is one runs a maf sensor and the other doesn't. Which makes no difference to you because you'll be running it off your stock electronics. As long as it's not an avcs version you'll be fine. Link to comment Share on other sites More sharing options...
Helloreaper1 Posted June 13, 2014 Author Share Posted June 13, 2014 Mine has maf, what is avcs? So what you're saying is get the ej251 or ej253 and just put my ej22 intake and timing onto it? Link to comment Share on other sites More sharing options...
boattlebot Posted June 14, 2014 Share Posted June 14, 2014 Avcs is active valve control system, its subies version of veriable cam timing. Think vtech for subies Link to comment Share on other sites More sharing options...
Helloreaper1 Posted June 14, 2014 Author Share Posted June 14, 2014 Oh! Learning more and more each day. Hahaha, vtec for subies. Ive never heard that before Link to comment Share on other sites More sharing options...
boattlebot Posted June 14, 2014 Share Posted June 14, 2014 Only analogy I could think of cus most people into cars have some understanding about vtech even if its "it move camshafts on crapy hondas" so I went with that instead of saying something like think vct for subies. Vct is fords system btw and also I should point out that ive come across avcs delete kits for the ej257 if anyones intrested Link to comment Share on other sites More sharing options...
