dombek2k7 Posted December 26, 2010 Share Posted December 26, 2010 anyone no where the speed censor is?? im getting the er sp message on my speed gauge, an my needle is not moving. im guess its my speed censor... help?? Link to comment Share on other sites More sharing options...
m sprank Posted December 26, 2010 Share Posted December 26, 2010 All four ABS sensors at the wheels are speed sensors. You have 4. Link to comment Share on other sites More sharing options...
dombek2k7 Posted December 27, 2010 Author Share Posted December 27, 2010 well after this crazy snow we just got up here in ct, my speedo is working again but my e/t is still not working Link to comment Share on other sites More sharing options...
ssbtech Posted December 27, 2010 Share Posted December 27, 2010 So is a speed censor someone who drives around spraypainting speed limit signs with black paint? Link to comment Share on other sites More sharing options...
Scotty Posted December 27, 2010 Share Posted December 27, 2010 No, it is someone who is can redact at a really high speed. Link to comment Share on other sites More sharing options...
m sprank Posted December 27, 2010 Share Posted December 27, 2010 well after this crazy snow we just got up here in ct, my speedo is working again but my e/t is still not working Speed sensor is not bad. You spun a wheel in the snow. ECU saw a "faulty" reading. Once everything was corrected for a bit, the ECU is happy again. Link to comment Share on other sites More sharing options...
dombek2k7 Posted December 27, 2010 Author Share Posted December 27, 2010 Speed sensor is not bad. You spun a wheel in the snow. ECU saw a "faulty" reading. Once everything was corrected for a bit, the ECU is happy again. well when i got the er sp error message i was traveling down the highway perfect weather doing 75mph. then even yesterday with the snow, and doing some drifting it i still had the er sp message. this morning when i moved my car so i could get out the er sp message was there, i noticed it was working on my travel into work. so is the censor just defective due to the snow, or just showing signs of dying?? Link to comment Share on other sites More sharing options...
esco301 Posted December 27, 2010 Share Posted December 27, 2010 Same thing happened to me this morning. Slid around a corner a little... then a good five mins. later SP Error all the way into work. Then went out for lunch and the speedo was all over the place. Whats up with that! NO DRIFTING???? Link to comment Share on other sites More sharing options...
m sprank Posted December 28, 2010 Share Posted December 28, 2010 Each ABS sensor (1 at all four wheels) acts as a speed sensor. If any one of the four do not give an "accurate" reading, you get the "ER SS". The pick up for the ABS/Spped sensor is in the wheel bearing. If you spin any wheel, you take the chance of the "ER SS". If you have the car on stands and spin one wheel to much with the key in you will get it too. you can drift. just not on slippery surfaces. if you s=pin the tires with resistance (like dry roads) it does not happen. It seems to happen a LOT in snow. I have never seen a sensor half way bad. Not a bearing pick up either. They are either good or not. But, I have seen loose/bad connections and bad grounds cause faulty communication. Link to comment Share on other sites More sharing options...
dombek2k7 Posted December 28, 2010 Author Share Posted December 28, 2010 i was drifting last night not a problem so far, speedo was perfect this morning an last night... i really hope its not a sensor or my wheel baring, ive already had that replaced the week before xmas last yr! Link to comment Share on other sites More sharing options...
