FknBoss Posted August 3, 2014 Share Posted August 3, 2014 So I got everything straitened out with my legacy and this is the last issue I have.. For Now . I have searched around and found some stuff on a recall way back when for the cooling fan. If I pull the big 4 pin relay out it stops. So first thing I did was check and see if the relay functions and it does. So the relay is getting a signal to run. Where does the signal come from. I'm worried the ecu. Because that would mean it needs to be replaced. Link to comment Share on other sites More sharing options...
iNVAR Posted August 4, 2014 Share Posted August 4, 2014 If your car didn't have the recall done, then go do it. It should still be free. Link to comment Share on other sites More sharing options...
MrTris Posted August 4, 2014 Share Posted August 4, 2014 If your car didn't have the recall done, then go do it. It should still be free. This. If they're cycling, though, check to be sure you don't have the test connectors plugged in. Link to comment Share on other sites More sharing options...
FknBoss Posted August 4, 2014 Author Share Posted August 4, 2014 No its not cycling it's constant. Link to comment Share on other sites More sharing options...
ragman Posted August 4, 2014 Share Posted August 4, 2014 Is your A/C on? What happens when you turn A/C off? Link to comment Share on other sites More sharing options...
FknBoss Posted August 4, 2014 Author Share Posted August 4, 2014 I don't have that unit even on. Link to comment Share on other sites More sharing options...
Akasa Posted August 4, 2014 Share Posted August 4, 2014 Seeing as you have a MY05, it's a recall. Nothing to be alarmed about, but please, get it fixed as soon as you can. http://legacygt.com/forums/showthread.php/cooling-fan-relay-issue-now-recall-campaign-55332.html Here's all of the information that you need. Give your local stealership a call. Link to comment Share on other sites More sharing options...
FknBoss Posted August 4, 2014 Author Share Posted August 4, 2014 Well what the recall say is it replaced cooling fan relay number 2. That's not the one that is making it run. Which fan is rad fan and which is ac condenser fan. The driver side fan is what running. If I connect the test connectors the passenger one cycle on and off while the other continues to run. Link to comment Share on other sites More sharing options...
FJuan Posted August 4, 2014 Share Posted August 4, 2014 Had the same problem and the dealer had to replace my ECU when the recall came out. Haven't had the problem since. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
FknBoss Posted August 4, 2014 Author Share Posted August 4, 2014 My recall has been done.. GREAT! Now what.. Link to comment Share on other sites More sharing options...
FJuan Posted August 4, 2014 Share Posted August 4, 2014 You can still take it back. There has been other members that had to do it twice. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
FknBoss Posted August 4, 2014 Author Share Posted August 4, 2014 Guess ill throw some mechanical darts and put in a new coolant temp sensor Link to comment Share on other sites More sharing options...
FknBoss Posted August 4, 2014 Author Share Posted August 4, 2014 You can still take it back. There has been other members that had to do it twice. I just talked to the dealer they told me it was a once and done thing. Guess ill be calling SOA Link to comment Share on other sites More sharing options...
iNVAR Posted August 5, 2014 Share Posted August 5, 2014 May I inquire who you bought your car from? Link to comment Share on other sites More sharing options...
FknBoss Posted August 5, 2014 Author Share Posted August 5, 2014 So guy. It over heated I replaced the engine. Link to comment Share on other sites More sharing options...
covertrussian Posted August 5, 2014 Share Posted August 5, 2014 Start the car with climate control off (no AC), does the fan run? Then start the car with AC on, turn AC off does the driver side keep on running? I seem to be having the same issue, but mine only constantly runs if I start the car with AC on. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
FknBoss Posted August 6, 2014 Author Share Posted August 6, 2014 Yes it always runs. I always have the climate control off my ac isn't charged yet I just put the engine in. Ac fan will run while ac is on that's normal. Link to comment Share on other sites More sharing options...
covertrussian Posted August 6, 2014 Share Posted August 6, 2014 Fans running while AC is on is normal, but they should turn off when you turn off the AC. Mine will run until you shut the car off and turn it on with AC off. Sounds like your ECU is fried though, 100% on = relay that already burnt the ecu. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
FJuan Posted August 6, 2014 Share Posted August 6, 2014 Sounds like your ECU is fried though, 100% on = relay that already burnt the ecu. You are correct. That's what happened with mine, even though it didn't change the driveablitly of the car, it just messed up the cooling fans circuits. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
