Oil-synthetic or dino
Lgt 2006 stage 2 145k miles. Daily driver. Is there a consensus as to using dino oil (I changed at 5k) or synthetic oil (I switched and am changing at 5k). Synthetic is much more costly. Does it make a difference?
thanks
gary
LGT? Yeah, peanut oil is the only appropriate lubricant. High flashpoint, high in Omega 3-6-9 fatty acids, just a great all around lipid.
Sounds like somebody had to much Redbull this morning. :)
Poor new guy.
I used dino oil for my first 154,000 miles. OCI between 3750 and 5000 miles. The turbo went at 142,000 miles. I replaced the short block at 154,000 because of oil useage and I plan to keep the car for a long time.
I could have kept the orginal short block in there and kept adding oil, but I didn't want to.
Now I use Amsoil European 5w-40 with 5-6000 mile oil changes.
OP there are a ton of oil threads. Read them!
The important thing is to keep the oil topped off, NEVER,NEVER,NEVER let it get low.
Engine Build - Click Here
This.
I'm a dick because this question gets asked far too much. All you gotta do is do a bit of searching, or look at stickies.
I'm relatively new and wondering if this would be an appropriate response post:
"this has been asked to death... to death..."
but seriously, either way has its fans. dino or synth. lots to search.
BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT
Personally, I wouldn't try to push conventional oil to 5k unless you're doing basically all highway miles. After 3750, the conventional oil is looking pretty toast, and I'm 100% stock.
If you want to try it, just get am oil analysis. That'll tell you the correct answer.
For a few dollars more you can go from dino to syn oil. I believe the heat properties of synthetic or semi syn are better for motors.
I believe the OCI was lowered to 3750 because the car was originally spec'd to run dino.
Feel pretty comfortable with a good, non-mobil1 5w30 or royal purpal, syn oil running 7500 miles. Check oil level regularly.
This.
Don't worry, I know your a ... ;) LOL
You were just getting fed up with all the oil threads...
Us old timers get that way every now and then. lol
