djfrostsf Posted April 3, 2013 Share Posted April 3, 2013 Hey guys, I have a noise under my dash, I hear it when accelerate from a stop and when i stop. It sounds like water is accumulated under the dash and is rocking back and forth. Its driving me insane, so any insight would be greatly appreciated. Thanks, -T Link to comment Share on other sites More sharing options...
Mr. Sinister Posted April 3, 2013 Share Posted April 3, 2013 AC condensation drain line is probably plugged. You can see it underneath the car on the passenger side somewhere by the firewall. You can try blowing it out with compressed air or run a flexible wire up there to try and unclog it. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 3, 2013 Share Posted April 3, 2013 If that's not it, you need to get the air out of the coolant system. Jack up the right fornt corner of the car, remove the radiator cap, start the engine, let it warm up, squeeze the radiator hoses and watch for bubbles, if you have a turbo remove the turbo coolant cap instead and do this. cycle the heater, too. Top of the coolant when your done, I use Peak Global 50/50 premix. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ssbtech Posted April 3, 2013 Share Posted April 3, 2013 I hear water trickling just after turning on the car, but not later in the drive. Air in the coolant? Link to comment Share on other sites More sharing options...
Mr. Sinister Posted April 3, 2013 Share Posted April 3, 2013 Probably. Link to comment Share on other sites More sharing options...
06Spec.B Posted April 3, 2013 Share Posted April 3, 2013 I wonder if we have been hearing the same sound. Occasionally, I hear what sounds like water sloshing back and forth. It sounds like it is right behind the steering wheel. I have never been able to figure out what it is. It also drives me insane. You are not alone. Link to comment Share on other sites More sharing options...
NeOxXt Posted April 3, 2013 Share Posted April 3, 2013 I was hearing the same thing for a year after I bought my car. I replaced the thermostat last week along with the required coolant change and I have not heard the bubbles from the passenger foot well that I used to. I did the change using Max's method. Link to comment Share on other sites More sharing options...
cobb Posted December 17, 2013 Share Posted December 17, 2013 I have had the same problem for some time, after removing the glove box and watch the servo that controls the flapper to the vents for dash and feet i noticed the noise was coming from it. i watched it twitching even after the car was turned off. I took the servo apart and cleaned the contacts and it was fixed that easy. the hardest part is getting it out. Link to comment Share on other sites More sharing options...
ssbtech Posted December 17, 2013 Share Posted December 17, 2013 cobb, I don't think you're hearing water trickling. The AC actuators make a different sound. Link to comment Share on other sites More sharing options...
Leviman Posted December 18, 2013 Share Posted December 18, 2013 You're hearing low coolant. Top off your coolant (not just the overflow). I've had this before as well, it was coolant. And the heater core is near the center of the car I believe, so sounds about right. Link to comment Share on other sites More sharing options...
