loups Posted March 8, 2012 Share Posted March 8, 2012 Hi everyone! I'm a new member, and happy to be part of the forum. I just found this burnt wire at the back of my engine, not sure if its an oxygen sensor wire, horn, etc? its a single wire with a green stripe? Help please Link to comment Share on other sites More sharing options...
Max Capacity Posted March 8, 2012 Share Posted March 8, 2012 Any wire that long may be from something aftermarket. Can you pull the engine cover and see where the wire goes/comes from ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
loups Posted March 9, 2012 Author Share Posted March 9, 2012 I'l check that out, I'm pretty sure it is contained in the stock wire sleeves that circle the engine. I think it's the EGT sensor wire... any comments? Thanks for the response tho! We are getting closer.... Link to comment Share on other sites More sharing options...
slowGT Posted March 9, 2012 Share Posted March 9, 2012 No check engine lights? Or any other warning lights? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 9, 2012 Share Posted March 9, 2012 Not EGT wire. That is a gray connector under the big main connector above the turbo. I think you can see the big connector in the picture. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bmx045 Posted March 9, 2012 Share Posted March 9, 2012 it's probably the ground wire thats suppose to mount next to the pitchstop dog bone Link to comment Share on other sites More sharing options...
loups Posted March 9, 2012 Author Share Posted March 9, 2012 Thanks! looks like bmx045 is right! problem solved. Link to comment Share on other sites More sharing options...
bdub Posted March 10, 2012 Share Posted March 10, 2012 Exact same wire sheared off on my car. Used it as an excuse to do the grounding mod lol. Link to comment Share on other sites More sharing options...
