MPacMan15 Posted October 13, 2016 Share Posted October 13, 2016 I'm changing my wheel/tire and suspension setup for the spring and came across the wheels I am looking at with tires on a local craigslist only thing is they are a lower offset than I was going to get 18x9.5 et20 (I was gonna get et35) they have a 225/40 tire on them and I have rear camber bushings and camber adjustable coilovers. Will I be able to get these to fit with some camber/roll/pull or are they just too low of an offset? Thanks! Link to comment Share on other sites More sharing options...
magnusonsubie Posted October 13, 2016 Share Posted October 13, 2016 An aggressive roll and slight pull and some camber and you should be able to get them to fit. It will be a very much stancenation #hellaflush look but it should work. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
rizzors25 Posted October 13, 2016 Share Posted October 13, 2016 You would have to add some serious camber even with stretch . FYI they'll stick out 71mm (2.8") wider than STI wheels... Link to comment Share on other sites More sharing options...
quick4dr Posted October 13, 2016 Share Posted October 13, 2016 your alignment specs will be a joke, I would avoid! I run 17x9+35 with 265/40/17 front is cut and fender flared, rear is rolled, relief cut and pulled I run -1* camber all around 0* toe. that wheel size isn't worth the work, and your tires will be short lived Link to comment Share on other sites More sharing options...
whitetiger Posted October 13, 2016 Share Posted October 13, 2016 totally not worth the effort to make these fit. Link to comment Share on other sites More sharing options...
MPacMan15 Posted October 13, 2016 Author Share Posted October 13, 2016 Thanks guys! ill stay away from them then and look for something in the mid 30s range Link to comment Share on other sites More sharing options...
whitetiger Posted October 13, 2016 Share Posted October 13, 2016 no, low to mid 40's and 8.5" wide. Link to comment Share on other sites More sharing options...
magnusonsubie Posted October 13, 2016 Share Posted October 13, 2016 no, low to mid 40's and 8.5" wide. This! For a useful functional wheel set up. I was assuming because of your original question though that you were looking to be hellaflush stancenation type of wheel fitment with 6+* camber. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
MPacMan15 Posted October 14, 2016 Author Share Posted October 14, 2016 That is my exact current setup (18x8.5 et40 enkei kojins) I'm looking at getting a second more aggressive setup Link to comment Share on other sites More sharing options...
magnusonsubie Posted October 14, 2016 Share Posted October 14, 2016 That is my exact current setup (18x8.5 et40 enkei kojins) I'm looking at getting a second more stancenation hellaflush setup FTFY You already have a pretty aggressive set up for these cars. Put some 245/35 tires on those and it will be aggressive. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
