knockoutgiant Posted May 20, 2014 Share Posted May 20, 2014 Hey guys, I'm looking at getting a new clutch in the future (looking into it more but might go with a CM FX350) now they've only got listings for the 2.5L turbo legacys. I have a JDM 03 Spec B with the 2L turbo and I was wondering if there are any differences to the clutches? I'm more wondering if a 2.5L turbo clutch will bolt directly onto my legacy? Cheers for any help guys! Link to comment Share on other sites More sharing options...
Max Capacity Posted May 20, 2014 Share Posted May 20, 2014 Contact one of the Vendors on here or PM m sprank, he owns http://www.infamousperformance.net he might know, or can get you what you need. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
idiot4hire Posted May 20, 2014 Share Posted May 20, 2014 I would also highly recommend a different clutch other then clutch masters. Unless you want to replace it yearly Link to comment Share on other sites More sharing options...
knockoutgiant Posted May 20, 2014 Author Share Posted May 20, 2014 Cheers Max I'll get in contact with them! I would also highly recommend a different clutch other then clutch masters. Unless you want to replace it yearly This is what I've been reading lately hence the reason I'm looking into them a lot more, would rather not replace it after 15k miles Link to comment Share on other sites More sharing options...
