Max Capacity Posted June 24, 2015 Share Posted June 24, 2015 I noticed the other morning that the rear wiper seems to be slower then normal on my wagon. Anyone have any ideas ? The wire harness through the hatch was replaced a couple years ago. So I kind of figure all the wires should still be whole. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 24, 2015 Share Posted June 24, 2015 either the motor is giving out from age or the wiring harness is saying fu again. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 24, 2015 Author Share Posted June 24, 2015 Yea, your thinking is the same as mine. lol 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
magnusonsubie Posted June 24, 2015 Share Posted June 24, 2015 When I bought my car the rear wiper didn't work. My initial thought after looking on here was the wiring but I pulled the motor and bench tested it and it didn't work. I think it is just the age of the motor is deciding it is done with life 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Max Capacity Posted June 26, 2015 Author Share Posted June 26, 2015 It rained last night, the rear wiper seemed a little faster the one time I used it. I wonder if a little Mystery Oil would help. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boxman Posted June 26, 2015 Share Posted June 26, 2015 Won't hurt. Link to comment Share on other sites More sharing options...
Harsho1 Posted June 26, 2015 Share Posted June 26, 2015 Some vegetable oil on the wiper blade rubber part should help it run faster. It will reduce friction with the glass! I suppose Marvel Mystery Oil will work too... Link to comment Share on other sites More sharing options...
