Andreu Posted September 17, 2009 Share Posted September 17, 2009 I have had ralliteks on spec B bilsteins for 7 months and love every bit about them except the front gap. i was thinking of was to fix it with spending the least possible as i shouldnt even be thinking about this. i was thinking about getting two front jdm pink springs and swapping the rallieteks out for them to lower the front just a little more. What do you guys think? Link to comment Share on other sites More sharing options...
BradyCat Posted September 18, 2009 Share Posted September 18, 2009 not exactly recommended, but that would get the job done, iONS would work too 2013 Ford Taurus SHO 2009 Spec.B SWP Stg 2+ Airboy tuned 2010 Toyota Sequoia Platinum 5.7 Link to comment Share on other sites More sharing options...
Andreu Posted September 18, 2009 Author Share Posted September 18, 2009 first off could i pick up just a front set of ions? would the ions be better suited? Link to comment Share on other sites More sharing options...
sactojesse Posted September 18, 2009 Share Posted September 18, 2009 I see no reason why you shouldn't mix the pinks F w/ Ralliteks rear. Any difference w/ spring rates will be negligible and you'll have even gaps. I'm running Bilstein HDs w/ pinks F and JDM LGT wagon springs R to get an even gap and it works! Link to comment Share on other sites More sharing options...
Andreu Posted September 18, 2009 Author Share Posted September 18, 2009 sactojesse, how does your car feel on hard corners and whatnot whats the overall feel of how it drives? Link to comment Share on other sites More sharing options...
kneedragger Posted September 18, 2009 Share Posted September 18, 2009 I'm running bilstein HD's with pedders front springs and oem rear with no adverse effects. Link to comment Share on other sites More sharing options...
GTkansan Posted September 18, 2009 Share Posted September 18, 2009 Ive got rallitek fronts and stock spec b's on the rear for now. Evens out the stance, but I may end up going to ions or swifts to have a more even spring rate setup. The car has some semi odd behavior (oscillation left and right) in a high speed sweeper that I want rid of. Link to comment Share on other sites More sharing options...
BradyCat Posted September 18, 2009 Share Posted September 18, 2009 first off could i pick up just a front set of ions? would the ions be better suited? Yes you can buy just the fronts in iONS. PM iON Performance and they (Jack) will respond promptly and he will give you two options - JDM sport spec or sport spec. JDM spec is lower (maybe too low), but both are supposedly made for the bilsteins. From all the research I've done, iONS and Pinks, with a nod to Swifts, are the most popular and best matched springs for the bilsteins. I went with iONS because of quicker delivery and a local (especially for me) vendor. 2013 Ford Taurus SHO 2009 Spec.B SWP Stg 2+ Airboy tuned 2010 Toyota Sequoia Platinum 5.7 Link to comment Share on other sites More sharing options...
Andreu Posted September 25, 2009 Author Share Posted September 25, 2009 hhmm are there any pics i can look at with the ions?? Link to comment Share on other sites More sharing options...
bmononana Posted September 25, 2009 Share Posted September 25, 2009 Ive got rallitek fronts and stock spec b's on the rear for now. Evens out the stance, but I may end up going to ions or swifts to have a more even spring rate setup. The car has some semi odd behavior (oscillation left and right) in a high speed sweeper that I want rid of. I'd be interested to hear more about this setup - i was considering going htech fronts/stock spec b rears. is there too much difference here as well? Link to comment Share on other sites More sharing options...
robinlsb Posted September 25, 2009 Share Posted September 25, 2009 I have had ralliteks on spec B bilsteins for 7 months and love every bit about them except the front gap. i was thinking of was to fix it with spending the least possible as i shouldnt even be thinking about this. i was thinking about getting two front jdm pink springs and swapping the rallieteks out for them to lower the front just a little more. What do you guys think? Miss-matched springs will look great, and handle like crap:eek: "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
sactojesse Posted September 25, 2009 Share Posted September 25, 2009 sactojesse, how does your car feel on hard corners and whatnot whats the overall feel of how it drives? It's pretty firm, but that's because the Bilstein HDs are substantially more stiffly valved than USDM Spec B Bilsteins. It drives great, IMO, and the floatiness of the stock dampers is gone. And, with the 20 mm JDM RSB, it feels very neutral. Link to comment Share on other sites More sharing options...
