jpapworth Posted October 18, 2007 Share Posted October 18, 2007 I just changed my spark plugs a few days ago at 61K. I used the NGK LFR7AIX plugs. Since I changed them I have gotten a violent stumbling or a misfire feeling above 3 or 4K under WOT. If I baby it I can go all the way up to 7K with it feeling fine. The only CEL I have gotten in P0102 for low MAF input. This CEl only stays on during the WOT and goes away right after I let the gas off. I took the maf out, cleaned it gently with a Q-Tip and reinstalled it with no change. While I was doing the spark plug change I also put in 2/3 can of seafoam in the gas tank for the first time. I was wondering if I am missing any steps before I pull all the spak plugs back out? Could the seafoam have caused this? Any help would be appreciated. Link to comment Share on other sites More sharing options...
jpapworth Posted October 18, 2007 Author Share Posted October 18, 2007 OK, this morning it finally threw CEl P0304, misfire in cylinder #4. I am trying to search to find out which one that is. Is anyone knows please let me know. Thanks! Link to comment Share on other sites More sharing options...
whitetiger Posted October 18, 2007 Share Posted October 18, 2007 did you break a wire on the maf connector? make sure no pins are bent on the connector and that evething is pugged in properly. Link to comment Share on other sites More sharing options...
jpapworth Posted October 18, 2007 Author Share Posted October 18, 2007 I checked and clean out all of the pin connections with canned air. They all look great. I thought of that too, but I only got the CEL for the MAf under WOT. I would assume that a broken MAF or pin would throw that CEL constantly, i.e. like its not plugged in. I just got it that cylinder 4 is the drivers side rear, figures it was the hardest to put it. So now I am going to let the car cool down and pull the plug. Link to comment Share on other sites More sharing options...
jpapworth Posted October 18, 2007 Author Share Posted October 18, 2007 All right, I am a dumba**. I cracked the porcelin on the plug for cylinder #4. I remember reading a thread about this a while back. I guess under light load everything was fine, but under heavy load something was arching or grounding through the cracks of the plug. I cleaned my best old plug and replaced it for now and everything is running fine. Now I just have to oreder a new plug and do it all over again. On a side note, I think the MAF CEL was unrelated but it was sure .ss hell dirty. Thanks everyone Link to comment Share on other sites More sharing options...
