SLegacy99 Posted June 3, 2007 Share Posted June 3, 2007 So I was listening to Car Talk today and a guy called in about his Accord. They told him the noises he was hearing was piston slap, a subject I dont really know anything about, and they said that this is common among Subarus and not really anything to worry about. However, they told him that Honda owes him a new engine because of the piston slap. Im just curious about the slapping of pistons I guess is what Im getting at here. Am I correct in presuming that Subarus are prone to this because of the horizontal engines? Link to comment Share on other sites More sharing options...
05LGTLtd Posted June 3, 2007 Share Posted June 3, 2007 porsche too... from what I understand... All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
SLegacy99 Posted June 3, 2007 Author Share Posted June 3, 2007 porsche too... from what I understand... Horizontal engines. Makes sense. Link to comment Share on other sites More sharing options...
Opie Posted June 4, 2007 Share Posted June 4, 2007 It's most common in 2000-2004 2.5 SOHC Subaru engines...not so common (but still occurs) in other Subaru engines... Link to comment Share on other sites More sharing options...
meier motor sports Posted June 4, 2007 Share Posted June 4, 2007 piston salp is when the piston is smaller then the cylinder and esentialy moves sideways or twists in the cylinder. slaping the piston skirt on the cylinder wall wall Link to comment Share on other sites More sharing options...
Bob N Posted June 11, 2007 Share Posted June 11, 2007 It's most common in 2000-2004 2.5 SOHC Subaru engines...not so common (but still occurs) in other Subaru engines... Actually it's more common in the 2.5 from 97-99. I have a 97 SUS and that baby sounds like a diesel until the metal warms and expands. Many 2000-2002 also have had this problem but not nearly as bad as the older 2.5. Link to comment Share on other sites More sharing options...
GTTuner Posted June 12, 2007 Share Posted June 12, 2007 piston salp is when the piston is smaller then the cylinder and esentialy moves sideways or twists in the cylinder. slaping the piston skirt on the cylinder wall wall Usually cars with loud piston slap actually have no piston skirt. The bottom of the piston is cut flat to reduce friction. This aggrivates the movement (slap) of the piston inside the bore at the top of the stroke. I worked on Honda's for 9 years, they have crazy piston slap cold! My Toyota with a 22RE did also. linky; http://resnet.uoregon.edu/~dwhite/pages/subnoises.html Link to comment Share on other sites More sharing options...
AWDxBOOST Posted June 12, 2007 Share Posted June 12, 2007 the ls1 and the like do it too Link to comment Share on other sites More sharing options...
qikslvr Posted June 13, 2007 Share Posted June 13, 2007 So does the first cylinder in EVERY Jeep Inline6 4.0L engine. They clack like mad until the engine warms up enough to open the thermostat. Let's kick this pig! Link to comment Share on other sites More sharing options...
AWDxBOOST Posted June 13, 2007 Share Posted June 13, 2007 bahahaha...the good ol 4.0 that motor has to have the loudest fan on earth Link to comment Share on other sites More sharing options...
qikslvr Posted June 14, 2007 Share Posted June 14, 2007 Ya, if you think your Subie makes a lot of noise; just jump in an old Jeep and all of a sudden your car doesn't sound so bad. My old motor had the slap; I put in a new crate motor about 30,000 ago after the oil slinger(50 cent keyed washer on crankshaft) spun and sent metal through the rest of the motor. Let's kick this pig! Link to comment Share on other sites More sharing options...
mike94stang Posted December 11, 2008 Share Posted December 11, 2008 there is actually a fix for the subaru piston slap on several engines, if your in warranty and you have a piston slap and not a tensioner knock, a local dealer w/ a good tech should be able to put updated pistons in the bank that has the slap. it can be verified w/ a stethoscope, if you are going to attempt it yourself, you will need to pull the engine, pull the affected head, get the right pistons, etc, it is a pretty extensive job. Link to comment Share on other sites More sharing options...
06gtleg Posted January 14, 2009 Share Posted January 14, 2009 if you have an intake and you take your car for what you think is piston slap. they figure its piston slap, can they blame it on the air filter Link to comment Share on other sites More sharing options...
terrangama Posted January 14, 2009 Share Posted January 14, 2009 there is actually a fix for the subaru piston slap on several engines, if your in warranty and you have a piston slap and not a tensioner knock, a local dealer w/ a good tech should be able to put updated pistons in the bank that has the slap. it can be verified w/ a stethoscope, if you are going to attempt it yourself, you will need to pull the engine, pull the affected head, get the right pistons, etc, it is a pretty extensive job. what is tensioner knock? Link to comment Share on other sites More sharing options...
