thyirishmen Posted January 7, 2011 Share Posted January 7, 2011 I installed a HID kit into my legacy today. It all went smooth and worked real well. I went for a test ride tonight and noticed that on my garage wall the right side is nice, but my driver side its all level but right in the middle is like a black shadow. I took a picture of both lights on the wall. and then one with just the right and the left covered. Anyone know what is causing this black shadow? I didn't touch the bulbs at all and the housing is clean. Link to comment Share on other sites More sharing options...
wizkerbizket Posted January 7, 2011 Share Posted January 7, 2011 How is the light coverage on the road? Is the gap noticeable then? Could it be just an adjustment/aiming problem? Link to comment Share on other sites More sharing options...
bakabakablah Posted January 7, 2011 Share Posted January 7, 2011 Perhaps you need to change the orientation of the bulb? Link to comment Share on other sites More sharing options...
sulk Posted January 7, 2011 Share Posted January 7, 2011 Yes double check the bulb is in correctly. I'd say take it out then put it back in, usually you put it in wrong. Link to comment Share on other sites More sharing options...
thyirishmen Posted January 7, 2011 Author Share Posted January 7, 2011 it has that notch can it still be rotated so the notch is 180 degrees? and still fit in? Link to comment Share on other sites More sharing options...
91subie Posted January 7, 2011 Share Posted January 7, 2011 i was wondering if its illegal in wa state to put in xenon bulbs Link to comment Share on other sites More sharing options...
Drift Motion Posted January 7, 2011 Share Posted January 7, 2011 you put in HIDs in Halogen headlight housing....that is your problem Link to comment Share on other sites More sharing options...
ehsnils Posted January 7, 2011 Share Posted January 7, 2011 how do you fix a return wire? If the light patterns looks different you have very likely mounted the bulbs wrong, either through using the wrong bulb or not seating it right. Link to comment Share on other sites More sharing options...
f1anatic Posted January 7, 2011 Share Posted January 7, 2011 The electrode wire is mounted in such way that it creates a shadow. You may not be able to fix that because automotive bulbs typically mount in one way only. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 7, 2011 Share Posted January 7, 2011 you put in HIDs in Halogen headlight housing....that is your problem This Link to comment Share on other sites More sharing options...
bmx045 Posted January 7, 2011 Share Posted January 7, 2011 This Putting an HID bulb in a halogen projector does not cause this visual defect as previous mentioned by the OP. I know a lot of 05+ legacy owners that have HID's in the stock housing w/o this defect. EDIT: I noticed this is a 2010, I wonder if they changed the projector. Link to comment Share on other sites More sharing options...
faded-a-fool Posted January 7, 2011 Share Posted January 7, 2011 Looks like the bulb isn't seated correctly. I can see the light from the squirrel finders are too close together. Should be a gap in between them. I have a 2010 with an aftermarket HID kit and all is well Link to comment Share on other sites More sharing options...
Drift Motion Posted January 7, 2011 Share Posted January 7, 2011 Putting an HID bulb in a halogen projector does not cause this visual defect as previous mentioned by the OP. I know a lot of 05+ legacy owners that have HID's in the stock housing w/o this defect. EDIT: I noticed this is a 2010, I wonder if they changed the projector. dont spread wrong information you can put HIDs in a halogen projector headlights nothing will blow up but see that glare in the pictures above the cut off that's what blinds ppl Link to comment Share on other sites More sharing options...
thyirishmen Posted January 11, 2011 Author Share Posted January 11, 2011 fixed it, I fixed the squirrel chasers and the bulb was half seated as stated. Thanks all. Looks great now. Link to comment Share on other sites More sharing options...
starbai007 Posted January 16, 2011 Share Posted January 16, 2011 How much work was involved in killing the squirrel finders? Can you post some pics of the cutoff now that the finders are closed up? Link to comment Share on other sites More sharing options...
jranmann Posted January 16, 2011 Share Posted January 16, 2011 ...but see that glare in the pictures above the cut off that's what blinds ppl This could be a defeat of a safety feature to keep your non self-leveling units from blinding oncoming drivers...HID's are good for you, although at times not for them and contrary to some opinions, their safety counts too! Link to comment Share on other sites More sharing options...
ehsnils Posted January 16, 2011 Share Posted January 16, 2011 And there are HID bulbs specially designed for reflectors. Their designation ends with an "R". Link to comment Share on other sites More sharing options...
Yamarocket630 Posted January 16, 2011 Share Posted January 16, 2011 But the "R" HIDs are designed for HID reflectors, not halogen reflectors. HIDs in halogen PROJECTORS don't produce nearly as much glare as in a REFLECTOR housing. That is not to say it is legal or doesn't produce ANY glare. If they are aimed down (hot spot should be 4-5" below the center of the lamp at 25' out) and the "squirrel finders" are closed up about 75% the glare is negligible. Link to comment Share on other sites More sharing options...
TRSCobra Posted January 16, 2011 Share Posted January 16, 2011 But the "R" HIDs are designed for HID reflectors, not halogen reflectors. HIDs in halogen PROJECTORS don't produce nearly as much glare as in a REFLECTOR housing. That is not to say it is legal or doesn't produce ANY glare. If they are aimed down (hot spot should be 4-5" below the center of the lamp at 25' out) and the "squirrel finders" are closed up about 75% the glare is negligible. +1 Also, US DOT halogen reflector housings don't have ANY cutoff like halogen projectors do. Link to comment Share on other sites More sharing options...
starbai Posted January 17, 2011 Share Posted January 17, 2011 is it hard to to kill the squirel finders, and what's the cutoff look like once this has been completed? What's involved in closing up these squirel finders, I dont feel like doing a complete hid retrofit, even though it is amazing. What size projector's would fit in our 5th gen's anyways if I wanted to search hidplanet for some OEM stuff? Link to comment Share on other sites More sharing options...
