Anthony I Posted March 15, 2017 Share Posted March 15, 2017 So I need a new turbo.I have a 2005 Subaru Legacy GT and $600 cash and am debating on a stock turbo or a used aftermarket one.If I go aftermarket I was going to swoop up a Cobb tuner also from the PayPal credit line they offer.Can someone lead me in the right direction.Im very new to this stuff and need advice on what to do thanks Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 15, 2017 I Donated Too Share Posted March 15, 2017 what has happened where you need a new turbo... please tell us how the original turbo failed. There may be much more to this than just replacing the turbo I am afraid to tell you. Not news you may want to hear but... lets start with you letting us know how the other turbo failed and hope you got to it before anything happened, maybe you found a wobbly shaft? Link to comment Share on other sites More sharing options...
Anthony I Posted March 15, 2017 Author Share Posted March 15, 2017 Yes my cartridge I believe that is what it is called has lots of play and my seals I believe are bad.The person who I purchased this car from in December told me he had never had this turbo replaced and it's been 160kmiles.... Link to comment Share on other sites More sharing options...
Anthony I Posted March 15, 2017 Author Share Posted March 15, 2017 Also I noticed when I wasn't in boost when it peaked my oil level was fine for a week.I boosted more often for a week and noticed I kept needing to ad oil b4 discovering what I suspect to be my turbo fail. Link to comment Share on other sites More sharing options...
JustCallMeNick Posted March 15, 2017 Share Posted March 15, 2017 I'd avoid driving the car for the time being but it's good news that the turbo hasn't failed yet. It will if you keep driving it though. The danger sigmafour was alluding to is that when the turbo fails small metal fragments typically enter the oil system and it's quite common for that to take out the entire engine as well. Having all that done at a shop will cost you about as much as a whole other used Legacy GT (not an exaggeration). You should be able to have your original turbo rebuilt. I purchased a used turbo and had Mike at Tuning Alliance rebuild it for a very fair price. You'd have to ship it there and wait for it to come back. Obviously you can't really drive your car the way it is now regardless but the sooner you get the turbo rebuilt the sooner you're on the road again. Perhaps there's a good local place to you who can rebuild the turbo? If you tell us what area you're in, maybe someone will suggest a good place. Link to comment Share on other sites More sharing options...
Anthony I Posted March 15, 2017 Author Share Posted March 15, 2017 I'm in a auto class so I'm able to install it there as I have access to anything I could possibly need.This really stinks since I just got done installing a fresh clutch maybe 1500 miles ago so I havnt even had it back to long.Im located in the Bay Area if anyone has any suggestions. Link to comment Share on other sites More sharing options...
Rhitter Posted March 15, 2017 Share Posted March 15, 2017 Try as much as possible not to go into dept for a car. Especially fast parts... Compression and leak down test (you can do this at your auto shop class) Oil analysis from Blackstone for $25. If those come back good get your stock turbo rebuilt. My OBXT build Link to comment Share on other sites More sharing options...
Anthony I Posted March 15, 2017 Author Share Posted March 15, 2017 https://www.ebay.com/itm/322440071723 Any thoughts on this? Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 15, 2017 I Donated Too Share Posted March 15, 2017 Anthony. A member here JMP has rebuilt 100's of turbos for people on this forum. There will be a lot of people here who will vouch for his work. Contact him through his thread here: http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238.html Link to comment Share on other sites More sharing options...
MilesA Posted March 15, 2017 Share Posted March 15, 2017 https://www.ebay.com/itm/322440071723 Any thoughts on this?Better to go with someone you know or that has been recommended to you. A lot of resellers use cheap Chinese parts, you don't want that anywhere near your engine. Either rebuild your existing turbo, or work out a deal where you get an already rebuilt turbo from the rebuilder in exchange for your old turbo. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 15, 2017 Share Posted March 15, 2017 Clutch 1500 miles ago...to bad you didn't think to check the turbo for shaft play. That should always be done any time the down pipe is off . Send your turbo to Mike of TA or JmP. Mike happens to be one of the best Tuners for these cars. He's someone your going to want to know. Another trusted member near you www.infamousperformance.net, aka m sprank on here. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Anthony I Posted March 16, 2017 Author Share Posted March 16, 2017 Update: While searching Craigslist I found a low mileage stock vf40.Has about 50k miles on it.Owner said he swapped to a vf52 and didn't need it anymore so I picked it up.It seems like a solid turbo with zero shaft play.Going to throw it on to see how it is tommorow. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 16, 2017 Share Posted March 16, 2017 If you can replace the oil return hose at the same time. Be careful trying to slip the turbo inlet into the intake hose, they can tare the rubber very easy. Remember to use anti-seize compound on all the threads. We also recommend replacing the up pipe with a catless one. Make sure you put the small vacuum hose with the boost pill on the right side. The hose has a white line around it. this may help, http://people.csail.mit.edu/ilh/vacation/ In the back there is a section that show's how the systems flow. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MilesA Posted March 16, 2017 Share Posted March 16, 2017 It's a good idea to use fresh gaskets when you take apart the exhaust system, otherwise you tend to get leaks. Use OEM gaskets or the Grimmspeed gaskets. Gaskets should be multi-layer-steel type with an embossed fire ring. Penetrating oil such as Kroil or PB Blaster will help you take apart the bolted connections without too much trouble. Helps to apply penetrating oil several hours before or even overnight. Link to comment Share on other sites More sharing options...
Anthony I Posted March 16, 2017 Author Share Posted March 16, 2017 Clutch 1500 miles ago...to bad you didn't think to check the turbo for shaft play. That should always be done any time the down pipe is off . Send your turbo to Mike of TA or JmP. Mike happens to be one of the best Tuners for these cars. He's someone your going to want to know. Another trusted member near you www.infamousperformance.net, aka m sprank on here. My tranny got dropped so my down pipe didn't come off enough to check turbo Link to comment Share on other sites More sharing options...
