ricky santana Posted April 28, 2012 Share Posted April 28, 2012 I took my 97 OBW in for alignment and the rear lateral links are bent and all the bolts are frozen. This is causing the rear passengers wheel to wear uneven since the toe can not be adusted. I need some help, advice, suggestions since I am clueless on this. I've searched & read but not quite sure which way to go and don't want to waste time & money on this. So what are my options? Can I replace the rear lateral links myself? If so what options do I have? Is this what I need?http://www.ebay.com/itm/Rear-Lateral-Link-95-07-Subaru-Impreza-GC-GD-Red-Color-only-now-/170829988152?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1997%7CMake%3ASubaru&hash=item27c642c138&vxp=mtr Link to comment Share on other sites More sharing options...
BDII Posted April 28, 2012 Share Posted April 28, 2012 are you mechanically inclined? do you own a blow torch? You will probably need to heat them up to get them off. Be careful because your gas tank is right there. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
ricky santana Posted April 28, 2012 Author Share Posted April 28, 2012 Will a simple propane torch work? Link to comment Share on other sites More sharing options...
