doccrowley Posted February 3, 2011 Share Posted February 3, 2011 looking for some experienced help with the clunk in my front end. Had my mechaninc replace my Lower Control Arm bushings with the Whiteline LCA kit. Car, (especially cold mornings after sitting overnight) has a subtle clunk in the front end, L>R, only noticeable at very low speeds. Happens most commonly upon up/down suspension motion rather than off-camber or corners. Anybody ever notice any "break-in" of the whiteline kit and needed to adjust it after installation? Appreciate the input. Link to comment Share on other sites More sharing options...
sheppo9 Posted February 3, 2011 Share Posted February 3, 2011 Did you check to see if the bolts/nuts are done up tight? Check the front strut top nut too - the one that actually holds the strut (17mm I think). Link to comment Share on other sites More sharing options...
doccrowley Posted February 3, 2011 Author Share Posted February 3, 2011 Ooo, good idea on the top strut nut. I checked the 3 strut mount nuts and the strut tower bar was a bit loose. No impact on quieting down the clunk though. I'll check the top center strut nut. Thanks for the suggestions. Let's keep em coming! Link to comment Share on other sites More sharing options...
naimouasta Posted February 10, 2011 Share Posted February 10, 2011 maybe he fudged your ball joints. i know my ball joints are bad and they clunk. check by jacking up the wheel then just grab the wheel and shake it. if theres any clunking check for the source of the clunk. Link to comment Share on other sites More sharing options...
whitetiger Posted February 10, 2011 Share Posted February 10, 2011 +1 for ball joints. time for the ALK. Link to comment Share on other sites More sharing options...
doccrowley Posted February 10, 2011 Author Share Posted February 10, 2011 mechanic forgot to tighten one of the endlink bolts, sway shifted and ate up the Sway bushings. subie bushings go in tomorrow for this weekends track day, Monday sways and endlinks go on the car. Stupid UPS delays due to weather made them bump delivery from today til Monday!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
Max Capacity Posted February 16, 2011 Share Posted February 16, 2011 Oh yes, blame the poor UPS guy for the weather. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
doccrowley Posted February 17, 2011 Author Share Posted February 17, 2011 Edit: stupid weather delays for the UPS delivery. happy now? Link to comment Share on other sites More sharing options...
