Duty C Solenoid or Clutch Pack Failure
Symptoms:
1. Torque binding when turning
2. Lower than normal fuel economy
3. Lurching when I shut off the engine
Diagnostic Procedure:
1. I installed the 4EAT differential lock switch, and the switch does nothing. That was pretty frustrating. :(
2. I installed the FWD fuse to test, the light showed up on the dash, I drove in tight circles, and I still got torque binding.
Unexplained:
1. The AT OIL TEMP light does not flash or remain on.
My Questions:
1. Is my diagnosis of a failed Duty C Solenoid correct?
2. What would a DIY repair job of the solenoid and clutch pack entail in terms of parts, cost, and time? What would a dealer charge?
3. What is the time-frame, probability, and mechanic result of failure of the clutch pack?
  • I Donated
I'm not a transmission expert, but I might be able to lend a little bit of advise.
You did do normal diagnostics for the Duty C Solenoid. However, if the FWD fuse doesn't seem to get rid of the problem, I would look at two things.
Center Diff Failure (clutch pack)
If this is the case, you're probably best sourcing a new transmission. I don't know how the Subaru market is around you for used parts, but here locally I can usually pick up a 4EAT for anywhere between $200 - $400 with reasonable mileage on it.
Sourcing new parts for it will get pretty expensive....and outside of OEM parts, you may have trouble finding them. If you wanted to go this route, some years of the Nissan Pathfinder use the 4EAT with a modified bellhousing. I don't know if their 4wd models use the same center diff that we do, or if they use a normal transfer case. Could be something for you to look into.
Rear Diff Failure
Again, it would likely be cheaper just to find a used rear diff. One quick check you can do is jack up the rear of the car. Spin one of the rear tires. Feel / listen for any grinding. Make sure the tire on the other side is spinning in the opposite direction.
Regardless of what your problem might be, I would change the fluid in both your transmission and rear diff. DO NOT flush your transmission if its high mileage (100k+). Do a couple of drain and fills. Simple fluid changes sometimes go a long way in our cars....especially in the transmission. People have had some strange problems that fresh fluid fixed for them.
Have you checked your steering / suspension to make sure you're not having problems with that? I currently have a bad front strut mount (top hat) that is making my car feel like its getting torque bind while I turn.
Johnegg will likely chime in on this. He knows quite a bit about the 4EAT. I'm sure he can elaborate on what I've said more.
-broknindarkagain
My Current Project - Click Here
COME AND TAKE IT
"The only thing necessary for the triumph of evil is for good men to do nothing."
if the AT Temp light is not flashing at start up, then it is not the duty c. but if the fuse in does not relieve the binding, then it is the duty c. the solenoid disconnects the rear wheels. so this is an odd one.
i was all set to tell you about replacing the transfer clutch plates, but the duty c, with the fuse in, should eliminate the binding if it is working.
so , matbe more info. maybe check the fluid in the trans and replace it , drain and fill, maybe jack up the rear and turn the wheels by hand looking and listening for something wrong, maybe a rear wheel bearing, or the diff.
and last but not least maybe the TCU , trans computer. they can go bad. it is not common but since nothing about this fits the normal symptoms maybe the TCU.
one report has ''scorched'' or burn marks on the circuit board. another has no sign of trouble but an intermittent binding.
did you install the lock up switch before you tried the fuse? i would eliminate the switch, it can not help in this situation. the switch is intended to lock the drive line in 4wd for really bad road conditions like snow or for off road use. if you messed up the switch it may be part of the problem. maybe you switched the wrong wire.?
did you put any resistors in with the switch wiring?
tires all match, brand, tread, size, inflation.?
more info please.
first, drain and fill 3 times with driving and shifting in between.
97? gt? auto trans? how many miles?
more info please.
1. I tripled checked my wiring of the switch with a voltmeter. When the switch is in position 1, the voltage travels uninterrupted through the switch from the TCU to the Duty C with a range of .15-11V. I check the FSM and used the wire from pin 3 on the B55 connector. Before I cut it, I checked that the voltage is .15V for WOT in 1st gear and 11V with the FWD fuse installed. The car also had torque binding before I installed the switch. I believe this eliminates the switch and the scorched TCU possibility.
2. The tires are all the same size, make, and model. They are all properly inflated 32 in the front, 30 in the rear. They have mostly even wear. I haven't been able to rotate them properly because I have two dented rims in the rear. But regardless, shouldn't the installed FWD fuse temporarily eliminate the torque bind?
3. About 500 miles ago, I drained about 7/8 quarts of the ATF, replaced the filter, and replaced the fluid with Mobil1 Synthetic ATF in hopes the synthetic ATF would do the best at cleaning it out. That was probably the first time the fluid has been changed for the life of the car. It was in ok condition, with no large metal pieces or excessive metal filings. Since this, the torque bind has gotten better.
4. It is a Legacy GT 4EAT with 168,000 miles.
Thanks for the ideas. :)
I have thus come to the conclusion that the problem resides with a stuck transfer valve. The solenoid isn't broken because otherwise it would have a flashing AT OIL TEMP light at startup. The transfer valve is probably clogged with gunk because the ATF Fluid had never been changed before.
My course of action now is to replace the transfer valve and the solenoid (I believe they come together), and replace the clutch pack. I have had this binding problem for about 5,000+ miles, so I'd imagine I killed the clutch pack by now.
  • I Donated
Just source a used transmission. It will probably be much cheaper and easier. Throw it in and make sure it has fresh fluid in it
-broknindarkagain
COME AND TAKE IT
  • 2 weeks later...
Update:
I took it to Subaru of Pueblo to get the transfer valve assembly and clutch pack replaced. I don't have the experience or time to do it myself, because I am going to school right now. The stealership quoted me at $900 over the phone, so I dropped it off. Then they called up the next day and quoted me at $1,800. I said no way, came back, and picked it up. From what I have seen, that it way too high.
I threw in some SeaFoam TransClean in hopes of freeing up the transfer valve, but no luck. My shifts are much smoother, but I still have torque bind.
Does anyone know a reputable dealer, shop, or friend in the Colorado Springs area with experience who would be able to replace the transfer valve assembly and clutch packs for a reasonable price?
stealership was ripping you off, parts are about $90-$100 for the valve and ~$160 for the clutch pack, though you may have damaged the clutch hub which is part of the output shaft and would require replacement of that. but i can't imagine it costing that much.
i know a guy in colorado springs on a different forum. send me an pm with your email and i will forward it to him. he is very good, and knows his stuff. i do not know if he will work on your car. but it does not hurt to ask.
if you want to look for him he is lmdew on the www.ultimatesubaru.org forum. you may have to register to contact him. and new members can't receive private messages right away.
  • 2 months later...
I have received allot of mixed information, a local dealership said I needed a new clutch pack and solenoid with accessories, I didn't like there $700 in labor and $400 in parts so I decided to go to someone I knew and would like to give money to at a more reasonable rate. just when I chose a place to buy my parts http://www.subaruparts.com told me I needed to measure the original plate so they could order me the appropriate part but they were about $150 cheaper than my local dealership. subaru of america after 3 phone calls told me that the original equipment size for my car is 3.3mm subaru parts.com said that they would put in a 3.7 while the local dealership said they would put in a 3.3 without measuring. in addition subaruparts.com told me a failing clutch pack can cause the solenoid to fail. furthermore according to SOA if I get a clutch pack thats to small I will damage my solenoid and not have awd. if I get a larger one I will have torque bind and might damage the trans....
my car feels fine and only throws a tcu code 24 after long drives at freeway speeds. in the dirt it feels good like I'm getting at least some power to the rear. anyone had similar issues, what was the outcome? any help or advice appreciated.
Hmm, tough one, If the OE size was 3.3 I would probably stick with that. From what I have seen, SOA loves to sell solenoids. Honestly, as long as the electromagnet in the solenoid functions, and the valve moves freely, there shouldn't be an issue. Don't see how a failed clutch could damage it either, the fluid going through it is the same filtered fluid the rest of the trans gets. My only conclusion is that due to the somewhat above normal rate of TCV failure the dealers like to replace the TCV as a preventative measure against comebacks any time they open the back of the trans up. That too small a clutch could cause no AWD makes partial sense, but again, you can rarely go wrong putting the OE size back in. and larger would be more likely to damage the transmission then smaller. It is also possible your clutch pack is ok and can be reused, but for ~$160 it is a bit of cheap insurance since opening the back of the trans up is not fun or really that easy (I have done it several times) so, best to do it once and be done with it.
here is where it gets confusing there are oem sizes ranging from 3.3 into 4.something. they are for different 4eat's like forester.... the part number for this pressure plate set is 31523aa410. subaru parts.com said that due to ware I might need a larger one yada yada I'm sticking with the 3.3 but keep in mind it took me 3 callbacks from subaru of america asking questions so they could ask their parts department questions and give me the info I desired. I know how much of an expletive it is to get in there dropping the drive shaft then properly supporting the trans.... thats why I'm paying a shop with a lift to help me out with getting the car over our heads, I might learn something rather than get pissed off in a small space rofl
is the valve or (TCV) a separate part from the duty c solenoid? do you know the technical name or part number? all I get when googling is turbo control.... or other non related items.
  • 4 months later...
Hello All- I am hoping someone can me help me source parts for the same subject replacement: Clutch Pack/Duty C Solenoid.
Legacy has been sitting with a 16 flashing AT light for over a year: I have again decided to look at it Ran self diagnostic with the black connectors: got fault codes 33-speed-sensor, 24- Idle Air controll valve 31 Throttle position sensor & knock sensor: I Ran Sea-foam flush through the throttle body: cleared codes, ran self Diag. again. Car now signals code 24- IAC Valve and 16 flashes of the AT light at start-up..
From my research and your helpful posts it seem I will be seeking the following:
Clutch Pack
Duty C
IAV valve.
Vehicle specs:
1997 Subaru Legacy: 2.0 JDM (Dual Turbo)
Heavy Industries LTD
E-BDS
VIN# BDS-029458
Aplied Model BDSC48P
Option Code: AHC
Trim Code: 710
Engine Type: EJ20
Color Code: 51E
Transmission Type: TZ102YBDBA
Does someone know of an online source for parts for a 2.0 Subaru, any help would be most appreciated.
Regards::
Clutch Pack
Duty C
IAV valve.
Vehicle specs:
E-BDS
VIN# BDS-029458
Option Code: AHC
Trim Code: 710
Engine Type: EJ20
Color Code: 51E
Regards::
If you are in the US, use Car-Part.com
  • 2 years later...
well my first question would be "why did you put synthetic atf in it?" does it have synthetic in it already? did whoever switched it to synthetic flush it correctly? the effects of mixing synthetic and conventional oils are REALLY bad, not minorly bad, REALLY BAD.
Holy thread resurrection batman!
I put synthetic ATF in the car because I was attempting to free up the Duty C solenoid by any means necessary so as to not have to take apart the transmission to replace it.
And no, mixing synthetic and conventional is not always really bad.
wait... im batman?!? COOOOOL :D I don't look at the dates they were posted, I found this thread looking for help for another forum member with same kind of issues. now, to mr. mustang man, I did like the blinker fluid from amazon, worked very well in my car. awesome mustang tricks ;)
im just trying to get clarification for my problem. he pulled up this thread ,, but this is the one I was reading in the first place.. It's confusing.
Do I have a bad duty c solenoid or not?
96 legacy, torque bind issue.
with fwd fuse inserted the problem goes away.
this is what he said,, this is why i am confused..
then the duty c is working.
try a drain and fill 3 times with driving in between.
That's what im doing next, I have it all up on jacks.. going to change the trans filter and change fluid. Not flush it.
If that doesn't work, my plan is to swap the TCM from a 95 legacy parts car. Gotta find the module first,, cant find my hanes manual!
there is no filter to change, just a screen.
if the screen is clogged, metal chunks, then the trans is bad.
so it is not worth the time or trouble to drop the pan.
plus, sometimes they leak after opening.
it is pretty rare for the TCM to cause binding, but it has happened.
look for scorch marks on the circuit board.
but i'm betting new fluid will take care of it.
