Sylvester Posted March 17, 2015 Share Posted March 17, 2015 This is what I currently have on my car. 1997 2.5l outback. The next picture shows one that says it's interchangeable with legacy sand imprezas. Is this true? Link to comment Share on other sites More sharing options...
Sylvester Posted March 17, 2015 Author Share Posted March 17, 2015 This is the part that's listed as fitting both Impreza and legacy of the same year. Any advice? Link to comment Share on other sites More sharing options...
Park Posted March 17, 2015 Share Posted March 17, 2015 The one on my usdm and jdm had the same part number on them. Go to autozone.com and look for a coil pack for each car. If they're the same they are definitely interchangeable. Link to comment Share on other sites More sharing options...
Osei Posted March 18, 2015 Share Posted March 18, 2015 As long as the coil ends are the same, it will work. O. Link to comment Share on other sites More sharing options...
Sylvester Posted March 18, 2015 Author Share Posted March 18, 2015 As long as the coil ends are the same, it will work. O. Do you mean the plug? I made the mistake of buying a different coil for a legacy that supposedly fit my car and it didn't, so I don't want to do that again. You can see my original coil pack on the left and the coil pack that is listed as fitting but doesn't (it's physically bigger and doesn't fit). Link to comment Share on other sites More sharing options...
Osei Posted March 18, 2015 Share Posted March 18, 2015 As you can see the coil ends are different. You need the female end on the coil. The plug wire has a similar end to spark plug. You can even pull one from the salvage. O. Link to comment Share on other sites More sharing options...
DGR81 Posted March 19, 2015 Share Posted March 19, 2015 You could do a MSD mod. Link to comment Share on other sites More sharing options...
86bratman Posted March 19, 2015 Share Posted March 19, 2015 90-96 ej22e coils 93-96 ej18 and 96/97 ej25d coils are all interchangeable. The coil on the right is from a 97/98 ej22e or 98/99 ej25d. Link to comment Share on other sites More sharing options...
Sylvester Posted March 22, 2015 Author Share Posted March 22, 2015 Thank you, 86bratman, Are you saying, then , that this combo will work? These came from a 94 Impreza. I just want to double check. I guess it doesn't. After if it's DOHC or SOHC? Link to comment Share on other sites More sharing options...
