highlander Posted February 7, 2010 Share Posted February 7, 2010 Well the snow in the mid-Atlantic has finally cost me some minor damage.I traversed a frozen pile of snow in the road and 'removed' the left front fender liner.It is mostly intact, with only a small spot worn through fron dragging it a short distance so I do not need to replace that. I do however need some of the plastic body 'rivets' to reinstall it. I know the dealer crucifies folks for these $.05 parts. Looking for tips on a generic source or an online OEM. Thanks. T Vir Est Fatum Ut Perficio Concepta Suus Progenies. - Man is destined to fulfill the capacity of his lineage (i.e. Darwinism) Link to comment Share on other sites More sharing options...
KartRacerBoy Posted February 7, 2010 Share Posted February 7, 2010 Some folks have told me they've gotten them from places like Autozone. Much cheaper, too. Link to comment Share on other sites More sharing options...
bluesuby Posted February 7, 2010 Share Posted February 7, 2010 Autozone. Pretty good assortment of sizes available. Link to comment Share on other sites More sharing options...
JSK05LGT Posted February 7, 2010 Share Posted February 7, 2010 How many do you need? Im down the street from you and I think I may have a few... Link to comment Share on other sites More sharing options...
DGMwagon Posted February 7, 2010 Share Posted February 7, 2010 I had the same problem with deep snow pulling off plastic under the car. I found a quick fix in a largish white drywall anchor, the kind you put in first and then put a screw into. It fit the hole perfectly and can be tightened or removed easily with a philips screw driver. Link to comment Share on other sites More sharing options...
OhBe1 Posted February 8, 2010 Share Posted February 8, 2010 If the big ones, like those that hold the plastic splash panels under the engine, you'll need to go to the dealer. They were IIRC under $2 each. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
GTTuner Posted February 8, 2010 Share Posted February 8, 2010 Subaru uses strange sizes for the plastic "pop" rivets. Go to a parts store with an old one (if you have it, to comapre) and I have found late model Nissan underbody pan rivets fit decent. Link to comment Share on other sites More sharing options...
jagcars26 Posted February 8, 2010 Share Posted February 8, 2010 I found some at PepBoys. Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted February 8, 2010 Share Posted February 8, 2010 I just suck it up and order them from Fred Beans every time I pay for shipping anyways for another part. The OEM ones are made to fit. Never have had good luck with aftermarket pop clips. Worth it to buy OEM IMO. On the search for a new DD... Link to comment Share on other sites More sharing options...
bluesuby Posted February 8, 2010 Share Posted February 8, 2010 I just suck it up and order them from Fred Beans every time I pay for shipping anyways for another part. The OEM ones are made to fit. Never have had good luck with aftermarket pop clips. Worth it to buy OEM IMO. The larger OEM rivets for under the fender splash shields might be the way to go, but the aftermarket pieces work fine on the engine cover, airbox intake, and the oil filter trap door. Link to comment Share on other sites More sharing options...
