iyamdman Posted April 28, 2005 Share Posted April 28, 2005 Some times I try to shift into 3rd gear (manual 5), and it won't let me pushing me toward 5th. I have to back off and try again. Mostly happens when it is cold, but sometime when it is warm. Anyone else have this issue? Do you know if the Kartboy shifter bushings would help? Link to comment Share on other sites More sharing options...
wayne53 Posted April 28, 2005 Share Posted April 28, 2005 That happens to me for reverse, when cold. But it never seems to happen after driving a bit. -Tyler Link to comment Share on other sites More sharing options...
gt_ltd Posted April 28, 2005 Share Posted April 28, 2005 my 99 forester had trouble going into gear when cold, thats why i have a 5EAT now. This Space For Rent Link to comment Share on other sites More sharing options...
gtguy Posted April 28, 2005 Share Posted April 28, 2005 Something is wrong, it sounds like. My GT wagon (2nd allocation) is easy to engage in every gear, even first and reverse. Kevin Link to comment Share on other sites More sharing options...
sjg Posted April 28, 2005 Share Posted April 28, 2005 Ours has the same problem. It has only happened when getting started and the car is cold (usually just the first time shifting into third). Once the car is warmed up (really just a minute or two) the problem is gone. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted April 28, 2005 Share Posted April 28, 2005 Something is wrong, it sounds like. My GT wagon (2nd allocation) is easy to engage in every gear, even first and reverse. Kevin +1 Link to comment Share on other sites More sharing options...
Th3Franz Posted April 28, 2005 Share Posted April 28, 2005 Make sure you let the shifter settle in neutral briefly and then push it up for 3rd gear. That's the habit I've gotten into, and it's quicker and more accurate for me.. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Xenonk Posted April 28, 2005 Share Posted April 28, 2005 Nope, no such issues here. Keefe Keefe Link to comment Share on other sites More sharing options...
Deer Killer Posted April 28, 2005 Share Posted April 28, 2005 Make sure you let the shifter settle in neutral briefly and then push it up for 3rd gear. That's the habit I've gotten into, and it's quicker and more accurate for me..Yeah, that's called a clutch that binds.. Link to comment Share on other sites More sharing options...
timbuktu Posted April 28, 2005 Share Posted April 28, 2005 That happens to me for reverse, when cold. But it never seems to happen after driving a bit. -Tyler Ditto. Reverse sometimes locks me out (gotta double clutch to get it in), but all other gears are fine. Link to comment Share on other sites More sharing options...
