SpeedNeeder Posted June 28, 2010 Share Posted June 28, 2010 I was wondering, if after resetting my ECU or flashing, the IAM is reduced. Is there any point in doing data logs while the IAM is reduced? I can see monitoring for knock, but past that? Shouldn't we wait until the IAM is 1.0 again? Thanks My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
Spec B Posted June 28, 2010 Share Posted June 28, 2010 No point in logging with IAM<1, you will not be getting the full timing advance. Get it up to 1, then log. Link to comment Share on other sites More sharing options...
rao Posted June 28, 2010 Share Posted June 28, 2010 A ECU reset moves the IAM back to an amount set by the tune (stock is .5, most tuners set it at .7 or so) It takes a few minutes of driving around before it goes back to 1; there is no point iin logging until it is back to 1. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Spec B Posted June 28, 2010 Share Posted June 28, 2010 In my car, IAM goes up to 1 really quickly after a flash if I do a quick 60% throttle run from 3000-4500rpm. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted June 28, 2010 Share Posted June 28, 2010 You can drive with the IAM as one of your logging parameters. Once it gets to 1. you can pullover and remove it from the list of logging parameters, then log away. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
SpeedNeeder Posted June 28, 2010 Author Share Posted June 28, 2010 Thanks for the replies. My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
TSiWRX Posted June 28, 2010 Share Posted June 28, 2010 If you're logging for "power"-related tuning, there's virtually no reason to log, the way I see it, unless your IAM is max'ed (and anything less than a max'ed IAM, read before the session, would make me pause before trying to engage in a high-load WOT pull: i.e. "what caused my IAM to drop?"). Like the others have all said, IAM should really max itself out after a reset/reflash very, very quickly, without any particular external prodding or pushing. The "Vishnu Reset" used to be popular, but if it is even remotely possible that your car does have something mechanically awry, pushing it that way isn't the smartest thing to do, either. With a good tune, a car in good mechanical shape and with good fuel, the IAM should re-establish itself at max very, very quickly. As with what NSFW authored in his datalogging guides (and what logan said above - I need to type faster! ), just click and check on that parameter before and after the run, to be sure that all's OK. There's no real reason to datalog the parameter, unless something is wrong with the car and you want to see when IAM is pulled (but is that even helpful?). <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted June 28, 2010 Share Posted June 28, 2010 ^ bingo. The fewer parameters logged, the better the data. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
