O_vang Posted May 18, 2011 Share Posted May 18, 2011 Hey Guys, The other day I was driving and noticed that something was smoking under the hood. I was super worried so I stopped and pulled over to check. Looks like the smoke was coming from under the turbo :\ Turns out the axle boot was torn and is leaking grease all over the exhaust pipe. Now my concern is....do I get a new axle or should I just replace the boot? My car is @ 94000 miles. Any advice helps! thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted May 18, 2011 Share Posted May 18, 2011 I went to my local Advanced Auto parts last Aug and paid $80.00 for a new axle. I installed it myself. The axle has to come out to replace the boot. It's much quicker to just replace the axle. FWIW, I was at he Stealership the other picking up some o-rings for the intake. While I'm waiting for the parts guy, the Service Manager comes over to a lady in the waiting room. I overhear her, you need a axle boot, that's will be $280.00 for that job and you need brake pads, that's $520.00 for that. Guy's on here have said the dealers charge like $380 for a axle. Any place can get you a axle and install it if you can't. Don't let the dealer touch your car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
WhiskeyTango Posted May 18, 2011 Share Posted May 18, 2011 Same thing here took me a few hours but not "hard" http://legacygt.com/forums/showthread.php/removing-front-axles-without-removing-ball-joint-127203.html?t=127203&highlight=axle Link to comment Share on other sites More sharing options...
DocHolladay23 Posted May 18, 2011 Share Posted May 18, 2011 I have the same problem, like Max said it's best to just throw on a new axle, getting mine done tomorrow! [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
devobuzz Posted May 18, 2011 Share Posted May 18, 2011 I wouldnt change it until you need to. I have 20K on my axle that tossed out all the grease after I cut it installing struts. Link to comment Share on other sites More sharing options...
doctorbrody Posted May 18, 2011 Share Posted May 18, 2011 If you're going to do it yourself with hand tools, get a 3/4" drive breaker bar with a six-sided 32mm or 1.25" socket. I broke two 1/2"-drive breaker bars on that axle nut. I got this: http://subaru-car-parts.macautoparts.net/CV-Shafts-8224/6117750-2005-2009-Subaru-Legacy/ProductInfo.aspx Works great, shipped fast. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 18, 2011 Share Posted May 18, 2011 Like ^ said, you need the proper tools to do this job. If you have then it's easy. If you don't you'll wish you did in about 10 minutes. There's not much my 3/4" impact gun won't remove. Not that it's perfect, some Honda axle nut's have kicked it's butt. To remove the lower ball joint from the LCA you need a 5lb hammer. leave the nut loose on the ball joint and wack the LCA until it pop's free. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted May 18, 2011 Share Posted May 18, 2011 If you know how to take apart a CV Joint, then I say change the boot. It'll cost less than $20 to do. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
O_vang Posted May 18, 2011 Author Share Posted May 18, 2011 Thanks for the advice guys! Looks like I'll be getting a new axle. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 19, 2011 Share Posted May 19, 2011 Smart move. It's much quicker to swap axles then play with all that grease. I put together the Rob Moore Nitro Drivelines custom made front axles for the XXXX WHP civic. So I do know how these things work. For the money, replace the axle. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
goneskiian Posted May 19, 2011 Share Posted May 19, 2011 Count me in for this now too. Ugh. If the burning grease didn't stink so bad I'd leave it but I'll be under there installing some new stuff soon so I'll add this to the list. Have any of you experienced strange vibrations with the Empi axle from macauto? I've read of a couple instances of this. Cheers! Link to comment Share on other sites More sharing options...
Max Capacity Posted May 20, 2011 Share Posted May 20, 2011 Count me in for this now too. Ugh. If the burning grease didn't stink so bad I'd leave it but I'll be under there installing some new stuff soon so I'll add this to the list. Have any of you experienced strange vibrations with the Empi axle from macauto? I've read of a couple instances of this. Cheers! "Strange vibrations", sounds like some of the $40.00 free life time replacement axles for a Honda Civic. Once I had to replace 4 of them, "free life time replacement" before I got a good one. That wasn't the only instance have having to replace more then 1 or 2 before you get a good one. Good thing we have a trailer and truck to go get the car when my son called me to come get the car on the side of the road. The axle I got from Advance Auto Parts for my 05GT that they got from another local auto parts store that I paid $80.00 is fine. The box said 100% new parts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
goneskiian Posted May 20, 2011 Share Posted May 20, 2011 "Strange vibrations", sounds like some of the $40.00 free life time replacement axles for a Honda Civic. Once I had to replace 4 of them, "free life time replacement" before I got a good one. That wasn't the only instance have having to replace more then 1 or 2 before you get a good one. Good thing we have a trailer and truck to go get the car when my son called me to come get the car on the side of the road. The axle I got from Advance Auto Parts for my 05GT that they got from another local auto parts store that I paid $80.00 is fine. The box said 100% new parts. Thanks. Unfortunately I can't find any Advance Auto Parts stores in Washington State. I'm not sure I trust that they'll send the proper one if I order online. The search continues. Link to comment Share on other sites More sharing options...
lgtftw Posted May 20, 2011 Share Posted May 20, 2011 Thanks for the advice guys! Looks like I'll be getting a new axle. WAIT!!! don't do it, just fix it, I've been through hell with this same problem. I'm on my 3rd one in the past 8 months. These "re-manufactured" ones suck!! or at least sell me yours so I can fix it and put it in my car. Don't forget to get the seal for the trans and a new axle nut when you do this as well. Link to comment Share on other sites More sharing options...
