dbob3d Posted May 17, 2012 Share Posted May 17, 2012 Hello, My clutch has been acting weird. Every time its depressed, it makes a squeaking sound. And, after I've driven the car for a long period of time (like on the highway) or after it sits in the sun on a hot day, the clutch seems to get soft. Usually, even with the clutch pedal all the way down, when I try to go into reverse it grinds. I've looked at the slave cylinder, and it doesn't have fluid leaking out of it. Any way to check the master cylinder? Any other things that might be the cause? Maybe a simple flush will take care of the problem?? Thanks Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 18, 2012 I Donated Share Posted May 18, 2012 Its normal DOT3 brake fluid for the clutch....and it gathers moisture over time and becomes less efficient. You can try flushing it out. Another possibility is the rubber line that goes to the slave cylinder. It can wear out causing pedal problems. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
dspl1236 Posted May 18, 2012 Share Posted May 18, 2012 did certain years or models get a hyrdo clutch? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 18, 2012 I Donated Share Posted May 18, 2012 97 and newer -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 19, 2012 Share Posted May 19, 2012 Cable clutch ftw Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
bengt Posted May 21, 2012 Share Posted May 21, 2012 Mine did the same thing, got worse and worse and eventually wouldn't operate clutch at all. I pulled my trans out and found clutch release lever split where the pivot ball rides. Just a thought... Link to comment Share on other sites More sharing options...
iSooby Posted May 22, 2012 Share Posted May 22, 2012 Does your pedal ever only come back half way? Cause if yours is doin that too we have the same problem and I've been curious as to what it could be too lol. Mine does everything yours is doing and also when it gets to the higher rpm range and u depress the clutch pedal, it only comes half way back out unless you give it a little help. It does seem.like the actual clutch is still engaged at all. But the pedal stays half way down. Link to comment Share on other sites More sharing options...
joelwatts Posted May 22, 2012 Share Posted May 22, 2012 That sounds like a release problem for sure. Mine did that as well. Sticking halfway up. Turned out the t/o bearing was shot. Didn't make noise until the day before it let go. But it was sticking for about two weeks prior to that. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
iSooby Posted May 22, 2012 Share Posted May 22, 2012 Mines been doin that for a few months lol. What's the bearing you're talking about? Link to comment Share on other sites More sharing options...
dylanwaible Posted May 22, 2012 Share Posted May 22, 2012 Throw out bearing Link to comment Share on other sites More sharing options...
iSooby Posted May 22, 2012 Share Posted May 22, 2012 Expensive to fix? Easy to DIY? Link to comment Share on other sites More sharing options...
joelwatts Posted May 22, 2012 Share Posted May 22, 2012 bearing is around $50. removed tranmission and there it is on the release fork. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
iSooby Posted May 22, 2012 Share Posted May 22, 2012 Ok. So not too bad then! Thanks for the info! Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 23, 2012 Share Posted May 23, 2012 easy if you have a tranny jack. other wise engine is better option BNR18g on 93oct Link to comment Share on other sites More sharing options...
