allante666 Posted October 22, 2010 Share Posted October 22, 2010 HI all I have a 2000 Legacy 2.5 GX on LPG. All ok except the LCD odometer just displays a series of dashes instead of the mileage! If i use it in trip mode, its fine so its not the dispaly itself which is at fault. Any Ideas?? Link to comment Share on other sites More sharing options...
chillij715 Posted October 23, 2010 Share Posted October 23, 2010 mayb u drive it so much its tired of counting? Link to comment Share on other sites More sharing options...
Van Johnson112 Posted October 23, 2010 Share Posted October 23, 2010 this happened to my friends volkswagon, turns out he had a dying battery. Link to comment Share on other sites More sharing options...
allante666 Posted October 24, 2010 Author Share Posted October 24, 2010 Yeah i considered the battery, i have a BMW 7 which if the battery drops even slightly it throws all sorts of errors at you and puts the transmission into limp mode! However...brand new battery so not that! Link to comment Share on other sites More sharing options...
quicklook2 Posted October 25, 2010 Share Posted October 25, 2010 corroded cables? Link to comment Share on other sites More sharing options...
allante666 Posted October 26, 2010 Author Share Posted October 26, 2010 dont know, im guessing the signal comes from the speedo head and its all in the same bit. The signal from the g/box must be ok as the trip and speedo work fine. I think it will remain a mystery unless someone with the same fault comes along with a quick fix! Link to comment Share on other sites More sharing options...
bwindle Posted May 18, 2017 Share Posted May 18, 2017 Try to track down a similar issue [LINK] with my girlfriends 2007 legacy.... very sorry to dig up a dead thread but allate666 did you ever find a solution/resolution to the odometer dashes> Link to comment Share on other sites More sharing options...
RumbleRumble Posted May 18, 2017 Share Posted May 18, 2017 Battery wouldn't cause but sounds like a bad cluster. Link to comment Share on other sites More sharing options...
bwindle Posted May 19, 2017 Share Posted May 19, 2017 alright, well it looks like used clusters are a dime a dozen on ebay so I'll have to see if I my mechanic can reprogram the keys at least if not the odometer. Link to comment Share on other sites More sharing options...
