Ibenz Posted September 15, 2012 Share Posted September 15, 2012 I have a clicking that is very loud when turning to the right at low speeds. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted September 15, 2012 Share Posted September 15, 2012 That would be a bad axle, my friend. Most likely the passenger side. Check the boots for tears. Link to comment Share on other sites More sharing options...
SomethingWittyAsAUsername Posted September 15, 2012 Share Posted September 15, 2012 Here's another vote for the axle. Check your boots and fix it ASAP if It's broken. Broken axles are no fun. Link to comment Share on other sites More sharing options...
odycee Posted September 15, 2012 Share Posted September 15, 2012 Torn CV boot at passenger side common problem. How do we know it's on the passenger's side? Because it sits on top of the cat with a lot of HEAT. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted September 16, 2012 Share Posted September 16, 2012 Both driver and passenger sides are equally apt to fail. Also, they don't usually fail on the inside (close to the transmission) because MUCH more stress is on the outer part (at the wheel). Link to comment Share on other sites More sharing options...
syber_d Posted September 16, 2012 Share Posted September 16, 2012 Not the case with my set up. I have done a inner reboot once and gonna be doing a second replacement on the pass side in about 2 1/2 years all because of the heat soaking in. I think im gonna fab up a heat shield of some sort for the dp to keep heat off the inner cv boot. Any thoughts??? Link to comment Share on other sites More sharing options...
Ibenz Posted September 16, 2012 Author Share Posted September 16, 2012 Its the inside pass side. I've rebuilt the axel once about 4 months ago. Thanks for the help. Are the pass side and drive side the same axle? Also front to back? Link to comment Share on other sites More sharing options...
SomethingWittyAsAUsername Posted September 16, 2012 Share Posted September 16, 2012 Front axles are the same. However the rear axle varies from left to right I believe and is surely different from the front axles Link to comment Share on other sites More sharing options...
Ibenz Posted September 16, 2012 Author Share Posted September 16, 2012 Thanks, can i go ebay axles or should I go to a parts store? The one at the part store is $130 with lifetime warranty I believe. Link to comment Share on other sites More sharing options...
Ibenz Posted September 16, 2012 Author Share Posted September 16, 2012 something like this: http://www.ebay.ca/itm/FRONT-RIGHT-CV-AXLE-SHAFT-SUBARU-LEGACY-1995-1996-1997-1998-1999-/160831754915?pt=Motors_Car_Truck_Parts_Accessories&hash=item257251d2a3 Link to comment Share on other sites More sharing options...
