marv3028 Posted August 28, 2016 Share Posted August 28, 2016 Ok, I'm having an intermittent issue over the last two weeks where my 02 2.5 manual wagon will randomly start running only on cylinders 1 and 2. First time it happened the only code it threw was p1581. After looking around for a bit seeing nothing out of the ordinary I restarted and it ran fine. About a week later it happened again and I shut down and restarted with no issue. The next time it happened I pulled a code of p0171, again it restarted with no issue. The last two times it happened the only codes were misfire on 3 and 4. Now a couple things I noticed during this, occasionally the obd port wouldn't connect and when it happened while driving the throttle became ULTRA sensitive. Anyone have any ideas? Sent from my SM-N910P using Tapatalk Link to comment Share on other sites More sharing options...
RumbleRumble Posted August 29, 2016 Share Posted August 29, 2016 Has the car ever stalled out? How many miles on it? Sounds like coil pack or plug wires. take the spark plugs out and check them too Link to comment Share on other sites More sharing options...
marv3028 Posted August 29, 2016 Author Share Posted August 29, 2016 Has the car ever stalled out? How many miles on it? Sounds like coil pack or plug wires. take the spark plugs out and check them too Never stalled, just ran like crap on two cylinders. I pulled the wire for 4 while running and misfiring and saw nothing. I did the same for 2 and got a strong spark so I quickly reinstalled and the idle smoothed immediately. A few minutes later, after idling while I looked around, it started misfiring again so I repeated the wire pulls but on 3 and 1 with the same results. Also I have to add, it only happens after running for a while and the engine is hot. I'm leaning towards the coil but not 100% sure just yet Edit to add it has 270 + on it Sent from my SM-N910P using Tapatalk Link to comment Share on other sites More sharing options...
marv3028 Posted August 30, 2016 Author Share Posted August 30, 2016 Ok, this is driving me nuts. Did a whole bunch of driving today and not a single stutter Sent from my SM-N910P using Tapatalk Link to comment Share on other sites More sharing options...
xrayspecs Posted August 30, 2016 Share Posted August 30, 2016 sounds like the coil pack is on its way out. replacing that should take care of the issue. Link to comment Share on other sites More sharing options...
marv3028 Posted September 2, 2016 Author Share Posted September 2, 2016 Well, I swapped in a new coil today. Hopefully my diagnosis was correct. It's hard to be sure since it was hard to get it to misbehave when I was able to work on it Sent from my SM-N910P using Tapatalk Link to comment Share on other sites More sharing options...
