davekra Posted August 6, 2010 Share Posted August 6, 2010 I'm replacing the stock stereo in my '11 Outback with a carputer. I've got to measure the draw but it's running on the bench with a 4amp supply. Anyone know how much you can draw from the factory harness? Thanks, davidk Link to comment Share on other sites More sharing options...
mwiener2 Posted August 6, 2010 Share Posted August 6, 2010 factory fuse is 15-20 amps My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
davekra Posted August 6, 2010 Author Share Posted August 6, 2010 Thanks, yeah I saw the 15amp fuse, just didn't know if maybe the harness to the radio was limited below that. Thanks again, davidk Link to comment Share on other sites More sharing options...
SVXdc Posted August 6, 2010 Share Posted August 6, 2010 There are two power wires, each on its own fuse. In 2010 and later: Pin 3, +12V Accessory (switched), is on fuse #24 under the dash. 15 Amps. Pin 20, +12V Battery (constant), is on fuse #6 in the engine compartment. 25 Amps. This fuse also powers the harman/kardon amplifier (in vehicles that have that). I don't think these two fuses supply power to any other circuits. You may want to use pin 20 for your main power. The pin 3 wire in the radio harness is smaller -- only 20 gauge. Link to comment Share on other sites More sharing options...
davekra Posted August 6, 2010 Author Share Posted August 6, 2010 Great! Thanks for that info! I got home today and measured the draw of my system at 3.9amps. Looks like no sweat to use the factory harness. I had looked at the firewall and didn't see an easy way in so this is indeed good news. Just need to paint the bezel this weekend and I can install everything. Thanks again, davidk Link to comment Share on other sites More sharing options...
