rj95lss Posted January 23, 2013 Share Posted January 23, 2013 So I picked up a '93 "L" wagon last night for $1,800 - pretty excited. Its a one owner with 76,000 miles and in really nice shape, little bit of rust forming around the wheel wells, but not bad at all. The interior however is mint... The battery is new and the tires are good, although I would like to find some newer Subbie wheels for it soon. I was going to run by the parts shop tonight and grab some stuff to give her a little tune up right off the bat. Here is a list of what I thought I would grab for now: 5qt of 10w30 + filter air filter NGK plugs + wires BELT - the belt looks like it will snap at any minute Anything else you guys would suggest doing/buying now? I am going to change the diff fluids and tranny fluid/filter once the weather is nicer. BTW Link to comment Share on other sites More sharing options...
pleaidestar Posted January 29, 2013 Share Posted January 29, 2013 Not very high mileage so probably not...tranny is a 70,000 mile tune up and differential fluid is 100,000 mile tune up I believe, check for leaks and change whats necessary...other than that your probably good to go. Have you driven it or has it been sitting for a long period of time? If so there could be a number of things to do. Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 30, 2013 Share Posted January 30, 2013 Replace the fuel filter. Check out the mpg sticky in the second gen forum. Has the timing belt ever been replaced? Did you remove the timing cover to take a look? Clean your MAF sensor. Post some pics. Link to comment Share on other sites More sharing options...
mnstrmech Posted January 30, 2013 Share Posted January 30, 2013 ditch the 10w-30 and go rotella 5w-40....AWESOME OIL!!! get a pureone or purolator synthetic filter..... i have around 6000 miles on my oil and even though i use about a half quart or so every 2500 miles, (276800 miles) my oil is still clean!!! thats my .02...................... Link to comment Share on other sites More sharing options...
