sma11s101 Posted August 20, 2009 Share Posted August 20, 2009 I recently bought the cheapo vag-com cable off of ebay. I have been trying to get it to work with my 05 lgt wagon but just can't figure it out. The drivers all installed fine and when i plug it in it makes the little xp hardware ding. Also, in ecuflash it shows up in the bottom right the cable model or what not. When plugged into the car the little green led lights up too. The only problem is it just wont connect. I tried the Tari Racing software, wont connect. Ecuflash, wont connect. Romraider, connecting to ECU eternally. Anyone have an idea? Thanks, Alex Link to comment Share on other sites More sharing options...
qikslvr Posted August 20, 2009 Share Posted August 20, 2009 Check this thread: http://legacygt.com/forums/showthread.php?t=96737 Or this one: http://legacygt.com/forums/showthread.php?t=110768 Let's kick this pig! Link to comment Share on other sites More sharing options...
notthesnail Posted August 20, 2009 Share Posted August 20, 2009 After installing all the software I wanted to use (ecuF and RR on XP), one of which includes a driver for the cable, I then updated the cable driver using the drivers in the first link in the above post. I have had no problems using everything. Read and flash, no problems whatsoever. Link to comment Share on other sites More sharing options...
mikeislord Posted August 20, 2009 Share Posted August 20, 2009 Did you connect the green test jumpers? Link to comment Share on other sites More sharing options...
executor485 Posted August 20, 2009 Share Posted August 20, 2009 Did you connect the green test jumpers? Only have to do that for ECUFlash Also things to check... 1) Baud speed of the COM port 2) ECUFlash needs to be 1.29 3) You dont have any hardware conflicts with COM ports If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
sma11s101 Posted August 20, 2009 Author Share Posted August 20, 2009 I have the baud rate at the correct setting and have no other COM issues. Next to a portable harddrive this is the only usb device ever plugged in. I shows up as correctly installed within device manager. I haven't tried the old version of ECUFlash because I can't find it anywhere but if none of the other programs work either I doubt that that's the problem? Link to comment Share on other sites More sharing options...
Smada Posted August 21, 2009 Share Posted August 21, 2009 This may be a bit simple and you've probably checked, but did you select the right com port? One time I couldn't get the cable to work and it turned out I plugged into a different USB port from normal. Another thing may be the cable might not be plugged all the way on to the OBDII connector. I had that once too, it wouldn't flash because it was slightly off, but still showed up as connected. Sometimes it is the simple things that screw it up.. Link to comment Share on other sites More sharing options...
sma11s101 Posted August 21, 2009 Author Share Posted August 21, 2009 Ya I've checked all those things. Only thing left to try is maybe a different laptop. I'm beginning to think it may have something to do with the cable only costing $12 Link to comment Share on other sites More sharing options...
qikslvr Posted August 21, 2009 Share Posted August 21, 2009 Just want to make sure that you have the key turned forward to the "ON" position when you are trying to connect to the car. I've been using one of the $12 cables for years now with only minor configuration issues Let's kick this pig! Link to comment Share on other sites More sharing options...
notthesnail Posted August 21, 2009 Share Posted August 21, 2009 I am using ECUFlash 1.42.2595; RomRaider v0.5.2 Beta; Learning View 0.6a; SimpleTune v0.99e. As of a couple weeks ago, these are all the latest versions, and may still be. Make sure all the software you want to use is installed on your laptop. Download the latest driver for the cable and unzip. Plug in the cable. Go into Device Manager and uninstall the cable. Unplug the cable and reboot. Plug in the cable. Install the driver for the cable from the unzipped folder. If your laptop installs the driver without giving you the option to chose, then go into Device Manager and update the driver from there. Tip: the cable isn't all that long. Use the USB port on your laptop that is farthest left and back. Link to comment Share on other sites More sharing options...
