02603sec Posted December 10, 2012 Share Posted December 10, 2012 No noises 06 legacy gt turbo limited 182k. Drive a little bit car warms up and at stoplights a burnt rubber smell is coming through the heater vents. Under the hood, is?everything appears fine and tight. Anyone know what this is? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 10, 2012 Share Posted December 10, 2012 Have you looked up from under the car ? check the right front axle boots. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
doobaruGT Posted December 10, 2012 Share Posted December 10, 2012 I had the same issue but after a hard drive on some back roads, the smell is no more. I had also checked my right front axle boot thinking that was the culprit but it was good. I can't explain it but it's true. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
chucky_z Posted December 10, 2012 Share Posted December 10, 2012 You might not like this answer, but it's very likely you got a plastic bag or something caught underneath your car and now all thats left is the tiny remnants that are smoking you out. I would really, really check the bottom of your car thoroughly in-case that's not the situation though. Link to comment Share on other sites More sharing options...
ripemeat Posted December 10, 2012 Share Posted December 10, 2012 your shoes are burning, turn the heat down. Link to comment Share on other sites More sharing options...
Mill Posted December 11, 2012 Share Posted December 11, 2012 You sure its a burning rubber smell? Check you coolant and oil hoses around the turbo. Mine smells at a stop due to a leaking turbo coolant hose. Link to comment Share on other sites More sharing options...
doobaruGT Posted December 11, 2012 Share Posted December 11, 2012 ^this is a good idea Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
