Baddog Posted May 26, 2014 Share Posted May 26, 2014 So my 96 legacys blend doors or something are stuck. They won't switch to face or feet or anything anymore. Do I need to pull the dash out and see if something jammed the blend doors? Link to comment Share on other sites More sharing options...
mailman Posted May 26, 2014 Share Posted May 26, 2014 is the cable running from the control unit to the switch attached? I lost my clip and it won't stay attached. You can use your finger to move the switch. If that doesn't work then it's something deeper in. Link to comment Share on other sites More sharing options...
mailman Posted May 26, 2014 Share Posted May 26, 2014 Nevermind, I thought you meant hot/cold Link to comment Share on other sites More sharing options...
Stevo F Posted May 27, 2014 Share Posted May 27, 2014 Mine was like that when I bought my car last year and I needed a new climate control ($30 on Ebay) Link to comment Share on other sites More sharing options...
Kevlar_07 Posted May 27, 2014 Share Posted May 27, 2014 I have the same issue with mine turned out to be the mode door actuator. Its mounted under the left side dash on the air box assembly. Link to comment Share on other sites More sharing options...
stevenva Posted May 31, 2014 Share Posted May 31, 2014 Mine did that for the past couple years. (it works fine now-somehow it fixed itself) But anyway,, I used to change the blend door manually twice a year. Face for A/C months, Def/Floor for the rest of the year. Above and to the right of the throttle pedal is where the blend door cam is. It is white greasy plastic wheel with a slot in it. There is a plastic arm that moves in the slot. It was just getting hung up on mine. All I had to do was set the control where I wanted the air to come from, reach up and tap the blend door cam and it would move to the correct position. EDIT:It may not be the fix you're looking for but mine did "fix" itself. It may just need a few cycles to work itself out RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
