Lafta Posted April 17, 2012 Share Posted April 17, 2012 One of my automatic windows stopped working when pressing the window up/down button at the drivers control. When I went to the actual window that doesn't work, and pressed that button, it worked just fine. I pulled the fuse. Nope. Any ideas? Thanks in advance! Link to comment Share on other sites More sharing options...
rsmoove Posted April 17, 2012 Share Posted April 17, 2012 Move to Interior / Audio? Link to comment Share on other sites More sharing options...
subawang Posted April 17, 2012 Share Posted April 17, 2012 Driver's control switch Link to comment Share on other sites More sharing options...
spc2125 Posted September 12, 2014 Share Posted September 12, 2014 Bump. Window switch on rear driver side works fine. Driver control for rear driver window doesnt work going down.... BUT will work going up Link to comment Share on other sites More sharing options...
Claw Posted September 12, 2014 Share Posted September 12, 2014 Faulty switch cluster. There's a writeup here but it only deals with the driver's window; might be easier to replace the whole thing. Link to comment Share on other sites More sharing options...
jeannie Posted May 22, 2016 Share Posted May 22, 2016 I have this same problem with my passenger window. Did you ever find anything out? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
sashadg1 Posted July 5, 2016 Share Posted July 5, 2016 My driver's side cluster is broken too. The driver window switch on the cluster broke a long time ago , however, I could open and close the window, but would have to make sure I put the switch perfect in the middle or it would roll up or down... if u left it without centering it u would not be able to roll up or down for about 10 min.... now it does not work at all... luckily the last time I used it when it works I had the window rolled up but it really sucks not being able to roll my driver side window down ie. drive-thru windows driving with all the windows down sunroof open rolling my window down to talk to people I have to open the door I need to get this fixed. Link to comment Share on other sites More sharing options...
