mikesubie13 Posted March 5, 2014 Share Posted March 5, 2014 Just wanted to see if anyone is tuning the invidia q300 exhaust on there sedans ? I just installed mine last night and it was a tight fit !! Had to remove the heat shield by the dive shaft also rear y pipe very close to the control arms :/ over all very happy with the sound on an off highway on full throttle and just cruising looks great and fits the car well !!! Just wanted to see if anyone else had any issues with the set up !! Thanks everyone Link to comment Share on other sites More sharing options...
Drift Motion Posted March 5, 2014 Share Posted March 5, 2014 search you'll see there are a couple versions of the Q300 Link to comment Share on other sites More sharing options...
mikesubie13 Posted March 6, 2014 Author Share Posted March 6, 2014 Did some searching around found a few threads on the exhaust all about noise and sound . I'm pretty sure I have the v3 wanted to know what's the difference between the versions ? Also anyone notice that the exhaust does hang kind of low ?!? No big issue just something I noticed lol thanks Link to comment Share on other sites More sharing options...
adammc92 Posted March 11, 2014 Share Posted March 11, 2014 I just did mine this weekend, full invidia turbo back. My resonator was rubbing the drive shaft and the flex pipe was rubbing the drive shaft carrier bearing. What I did was chop and weld the crap out of the one section to clear everything. What I should have done the first time was get longer exhaust hangers. I don't know the brand but they sell longer rubber exhaust hangers to correct this issue. There cheap and my be worth looking in to. Link to comment Share on other sites More sharing options...
mikesubie13 Posted March 12, 2014 Author Share Posted March 12, 2014 I had the same problem, I also have a invidia down pipe and when I went to install I noticed my dp ( flange on the bottom) appeared to be bent up like the whole pipe was slightly bent upwards so I heated up the down pipe with a torch and was able to straighten it out . Once I did that fit fine just had to remove the heat shield for the driveshaft . It's pretty close to the carrier bearing but doesn't rub at all and has room to travel if need be . Oddest thing some how it appear my down pipe was bent ?!? Lol I am running one longer hanger from kartboy which did help with clearance issues . Other then that some pain in the ass I love the exhaust and everything about it lol Link to comment Share on other sites More sharing options...
2manysubies Posted March 13, 2014 Share Posted March 13, 2014 I have the Q300, I think the earlier version(no flex pipe), it is a tight fit but no rubbing issues, I have Tien S springs (about 1.5" lower than stock) I only scrape the road if it has a big crown and I have more than 3 people in the car and then only occasionally as the car settles after a big bump. the roads here in Maine truly SUC* in the winter.. but other than that, GREAT product. Really nice flanges too. Mac Link to comment Share on other sites More sharing options...
