subiegillis Posted April 3, 2015 Share Posted April 3, 2015 hey guys , need help ASAP here is the story last june i spun the bearing in my 2005 legacy 2.5gt , well i finally was able to get every thing bought and put back together , last night i filled the engine with all required fluids and oil , put the battery in and connect it up and got in the car and went to start it and nothing happen the gauges did their little sweep show then the temp gauge went to MAX and the odometer displayed ER HC, i have checked grounds and fuses, the car was with out a battery in it since around august last year .. i have done searched and haven't came up with a prime cause yet ... any help that anyone can provide it would be great ... i miss my car !!!!!!! Link to comment Share on other sites More sharing options...
doobaruGT Posted April 3, 2015 Share Posted April 3, 2015 Lots of options here Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
subiegillis Posted April 3, 2015 Author Share Posted April 3, 2015 we were goin over this post and tried it all and it is still there , won't crank over Link to comment Share on other sites More sharing options...
doobaruGT Posted April 3, 2015 Share Posted April 3, 2015 we were goin over this post and tried it all and it is still there , won't crank over Did you catch the issue with the harness? I don't know to which they're alluding, but it sounds tricky. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
doobaruGT Posted April 3, 2015 Share Posted April 3, 2015 See here and here also. Seems like there are some poor/damaged connections that need to be inspected. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
subiegillis Posted April 3, 2015 Author Share Posted April 3, 2015 something i forgot to add was we tried pulling codes in the acc. position the reader lite up but as soon as we put the key to ON postion it turned the reader off Link to comment Share on other sites More sharing options...
doobaruGT Posted April 3, 2015 Share Posted April 3, 2015 Can you pull codes from memory? Sent from my iPhone using Tapatalk Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
BrianEarlSpilner Posted April 3, 2015 Share Posted April 3, 2015 I had this issue for 2 days after a rebuild. It ended up being the grounds. There's one on the bottom of each head and don't forget the 2 connected to the TGV housings. I'm not sure but the ground on the starter could affect it as well. I know you said you checked them but so did I... hope you find the cause Link to comment Share on other sites More sharing options...
subiegillis Posted April 3, 2015 Author Share Posted April 3, 2015 got all the those grounds connected .... but will go through and check them when i get hold again and check the pins on the main connector in the engine bay also .... i just want my car running Link to comment Share on other sites More sharing options...
subiegillis Posted April 4, 2015 Author Share Posted April 4, 2015 I had this issue for 2 days after a rebuild. It ended up being the grounds. There's one on the bottom of each head and don't forget the 2 connected to the TGV housings. I'm not sure but the ground on the starter could affect it as well. I know you said you checked them but so did I... hope you find the cause Yup you were correct it was the tgv grounds ,we had disconnected them and forgot to put them back on!!!! THANKS AGAIN TO THE GUYS WHO POSTED AND THE QUICK RELIES AND SUGGESTIONS ☺ Sent from my SM-N910P using Tapatalk Link to comment Share on other sites More sharing options...
