highlander Posted December 31, 2009 Share Posted December 31, 2009 OK folks. I have a Stg2+ '05 LGT. I installed the ACT LWFW/HD street disc set up about 21 months ago. The car has not been raced, the clutch was ridden once for about all of 5 seconds about 18 months ago. I recently had a bearing go bad in the tranny that Subaru replaced. Ever since then, I notice after about 30mins of driving with some stop-n-go, that the clutch will shudder when starting off in 1st. Once it starts it gets progressively worse. 1. Is this uncommon premature wear of the assembly? 2. Could a small amount of lubricant on the surface of the disc/FW/PP cause this? 3. Is this a symptom of a warping FW/Disc? 4. Can the LWFW be machined if no longer true (yes I know there are limits if really bad)? Thanks for the feedback. Too tired to search all threads. Read some of bad experiences as well as good. T Vir Est Fatum Ut Perficio Concepta Suus Progenies. - Man is destined to fulfill the capacity of his lineage (i.e. Darwinism) Link to comment Share on other sites More sharing options...
