bcmaxx Posted February 18, 2016 Share Posted February 18, 2016 After installing headlight relay harnessess and piaa extreme whilte bulbs, I still find the headlamps very poor on this car. I decided to try out some led headlamps. http://i232.photobucket.com/albums/ee110/bcmaxx/20160218_072210_zpsluayys7u.jpg http://i232.photobucket.com/albums/ee110/bcmaxx/led-headlight-conversion-kit-flexible-tinned-copper-braid-h4-heatsink_zpsa9n8b59v.jpg http://i232.photobucket.com/albums/ee110/bcmaxx/20160218_112641_zpsaww436jc.jpg I'm not sold on them at all. Other than the color, they are no improvement . I like the white, but thats about it. I think I'll swap them back out, matbe try a different design, or just hold out for my bi zenon projector retrofit Link to comment Share on other sites More sharing options...
ItalianLegacy Posted February 18, 2016 Share Posted February 18, 2016 honestly best replacement bulbs without going hid in my opinion are the putco bulbs on carid.com Sent from my SM-G925V using Tapatalk Link to comment Share on other sites More sharing options...
mnstrmech Posted February 19, 2016 Share Posted February 19, 2016 I converted to HID/ projector system a couple years ago with a Morimoto system from THE RETROFIT SOURCE... BUT!!! if you dont do something about the lenses,,, you wont get that sharp cutoff or just that nice lighting..... http://i155.photobucket.com/albums/s305/sadiemaerogers01/0925140750_zps960b3d30.jpg I cutoff the front of my lenses and molded acrylic to them.... and ill never go back to halogen again...... the acrylic has been in about 2 years,,, and still crystal clear. Link to comment Share on other sites More sharing options...
bcmaxx Posted February 19, 2016 Author Share Posted February 19, 2016 Do you have a writeup at all on how you did your lenses with acrylic? I have a spare set of lenses I was going to sand the fluting from , and polish...but I'm looking at hours and hours on each lens Link to comment Share on other sites More sharing options...
mnstrmech Posted February 20, 2016 Share Posted February 20, 2016 Sorry, i dont have a write up. I did them about 2 years ago. I intially tried sanding the original ones from inside, but they just dont clear at all. Ina nutshell, i cut the very edge of the lenses right at the sharp bend, which i have a photo..... http://i155.photobucket.com/albums/s305/sadiemaerogers01/0922141209_zps335718fc.jpg I used an air cutoff tool, then smooth it out with a roloc disc on my air grinder... (since im an auto tech) Then trim the acrylic , which i got from Lowes, which is their optix line, .08 thick, about half inch or so LARGER than above cut piece. i heated it up in the oven. BUT!!!! 1st reassemble the cut part from above pic TO the headlamp assembly, that way it stays to shape. I read through a bunch of message boards about heating acrylic in the oven, low temps, below 250, i dont recall a good temp, just below 250. once its soft, then you can form it to the headlamp. Trim the formed piece closer to size. Now, I taped the acrylic to the headlamp, and used Loctite super glue in the INSIDE ( which means DIS-ASSEMBLY from the housing.).... THEN< went over that with a good silicone both INSIDE AND OUTSIDE.... A tip..... cover the outside of that nice new acrylic in some blue masking tape.... it'll keep you from scratching that clear acrylic.... i cut it about an 1/8 inch around the edge.. for a "border" then spray painted the sides and back black.. 2 Northern Indiana winters.... and still sealed.. No moisture getting inside!! Not even a scratch.... and my car NEVER sees a garage . So thats how i did mine..... in a nutshell. Hope that gives you encouragement to try it..... Link to comment Share on other sites More sharing options...
