roundthirteen Posted May 12, 2015 Share Posted May 12, 2015 So I've always used extra S in my 6mt and the Subaru "R180" LSD oil in the rear diff on my 08 Spec B. I went to buy some more R180 from Fred Bean and didn't see it but did see "Subaru Hypoid LSD oil" which they said was good in the 6 speed rear diffs. Anyone know any more, is this just a renaming? http://www.fredbeansparts.com/subaru-hypoid-lsd-oil-1-liter.html My car's not a sleeper it's a hibernator. http://pure-tuning.com Link to comment Share on other sites More sharing options...
ras06LGT Posted May 12, 2015 Share Posted May 12, 2015 The rear LSD is a sealed unit, so you should be able to use most any standard 75W-90 gear oil for the pinion sump. You can use Extra S, or another popular option is the Motul Gear300. Link to comment Share on other sites More sharing options...
Th3Franz Posted May 15, 2015 Share Posted May 15, 2015 The 08 Spec B has a helical/torsen rear diff. It's not clutch type so you don't need any friction modifier. Just run a standard gear oil. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
