Browland17 Posted October 4, 2015 Share Posted October 4, 2015 Hello there, My name is Ben! I just picked up a 1993 Legacy GT for $300. The kid who had it did a timing belt, full tune up, fuel filter, fuel pump, plugs, wires. Then it died. It would not start. I looked at it and he wanted $500 for it..... I said not at the moment. Fast forward about one month, and he text me yesterday asking if I still wanted it, $300 without wheels or tires. I went to a yard and picked up a set of wheels, went to his house and put them on, fired the car up and drove it on the trailer. The kid was dumbfounded it ran. ******UPDATED****** newer coil pack, runs better. I drove it across town today, it was super gutless until about 30mph, then it took off like a rocket. we determined the turbo is not getting enough air unless I'm driving it. I also replaced the wires. the intake and turbo was pulled, turbo is nice and tight, no shaft play. My "DSM god" buddy who knows turbo motors inside out, said the air control valve might not be opening up correctly.. gonna look at it tomorrow Link to comment Share on other sites More sharing options...
Browland17 Posted October 6, 2015 Author Share Posted October 6, 2015 Ended up replacing coolant temp sensor, runs better but still won't idle for a shit. Saw on YouTube that replacing vacuum lines does the trick... Ideas? Link to comment Share on other sites More sharing options...
bcmaxx Posted October 6, 2015 Share Posted October 6, 2015 How is your belt timing? Link to comment Share on other sites More sharing options...
xtech210 Posted October 7, 2015 Share Posted October 7, 2015 not sure if its the same on a turbo, but on my 91 legacy, i had a CEL for code 35(canister purge valve). idle was shite. car would vibrate enough to cause my fat rolls to jiggle replaced it, idle is so much smoother. also check the coil pack for corrosion. mine had a fair bit in it. cleaning it all out pretty much smoothed out the idle. the idle air control valve would cause a wild swing (in hondas at least) in your idle. im talking 1500 > 500 > 1500 back n forth. i had that issue in my turbo h22 accord about 10 years ago. Link to comment Share on other sites More sharing options...
monkeyposeur Posted October 8, 2015 Share Posted October 8, 2015 Definitely clean your idle air control valve (IACV). Purchase a new gasket for it though at the dealer. Soak it in gasoline and spin the barrel around and clean it up with a qtip. Check all your vacuum lines too. A boost leak test is a good idea. I did a write up: http://legacygt.com/forums/showthread.php/diy-boost-leak-tester-ss-199337.html When I wrote that DIY I didn't have an air compressor so I used a bike pump. BE careful with your turbo inlet elbow though. They break by looking at them and are no longer available so if you break it you will have to make one. You can also spray starter fluid or carb cleaner on all your vacuum connections to help find vacuum leaks. If the idle surges when you spray a particular connection that indicates a leak. I had to replace every single vacuum line, coolant, hose, pcv line on my SS. They become brittle and break over time. Link to comment Share on other sites More sharing options...
bcmaxx Posted October 8, 2015 Share Posted October 8, 2015 I can still get 2 or 3 inlet elbows in Canada. I just got one last week. But there's no stock left after those Link to comment Share on other sites More sharing options...
Browland17 Posted October 8, 2015 Author Share Posted October 8, 2015 Thank you for the input Link to comment Share on other sites More sharing options...
wtdash Posted October 14, 2015 Share Posted October 14, 2015 Hi, To clarify as this is commonly misunderstood your car isn't a GT unless it's an import from JDM or oveseases. It's a Sport Sedan. The USA GT didn't arrive 'til '94, regardless of this site's use of Generation years. It was NOT turbocharged, had the raised roof like the '96+ Outbacks, but the rest of the sheet metal was the same body style as the '89-'94 models. And same non-turbo EJ22e. Read up HERE. Enjoy the new wheels. Link to comment Share on other sites More sharing options...
Browland17 Posted October 29, 2015 Author Share Posted October 29, 2015 Thank you, I later found that out when I ran the Vin number Link to comment Share on other sites More sharing options...
Browland17 Posted October 29, 2015 Author Share Posted October 29, 2015 Never Guess what it was?! The camshaft on the passenger side of the motor was 30* off! We reset the timing on the car and she PURRRS so well and has so much boost and power! Thank you all for the help! Link to comment Share on other sites More sharing options...
GTEASER Posted October 29, 2015 Share Posted October 29, 2015 Hahaha! Seems the kid messed up the timing belt replacement. You got a nice deal from someone's mistake. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
