1-3-2-4 Posted January 31, 2015 Share Posted January 31, 2015 Anyone in the CT area that knows someone that does wheel bearings? I'm almost 100% sure mine went out on the highway, I was in the 3rd lane and all of a sudden the car got very wobbly in the rear with a lot of noise like popping sounds and rubbing.. I ended up doing 25 mph for the rest of the way home, my ABS light also came on. Link to comment Share on other sites More sharing options...
bluesuby Posted January 31, 2015 Share Posted January 31, 2015 How long were you putting up with that humming noise in the rear end? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 31, 2015 Author Share Posted January 31, 2015 How long were you putting up with that humming noise in the rear end? I had none what so ever Link to comment Share on other sites More sharing options...
aac0036 Posted February 1, 2015 Share Posted February 1, 2015 the car got very wobbly in the rear with a lot of noise like popping sounds and rubbing.. I ended up doing 25 mph for the rest of the way home, my ABS light also came on. That sounds a lot more serious than a wheel bearing. Although every wheel bearing failure I've ever heard sounds different they usually tend to hum or make a light grinding sound on the highway, none of which involves wobbling or popping. Also your ABS light would have no reason to go on if a wheel bearing failed. Not sure what to tell you honestly. Make sure your wheels are on properly or balanced. Get under there and try jiggling stuff about. ABS lights can come on sometimes if a wheel speed sensor is damaged. If you go to Autozone or any Autoparts store they might be able to read it for you. Not all places have readers that reads ABS or SRS (airbag) codes. Link to comment Share on other sites More sharing options...
HDTurbo Posted February 1, 2015 Share Posted February 1, 2015 yeah. mine annoyed me with a rotational speed dependent hum for thousands of miles before I replaced mine. and I replaced the wrong one due to it being an inner v outer race issue!!! rear, not front!!! Link to comment Share on other sites More sharing options...
HDZ32 Posted February 1, 2015 Share Posted February 1, 2015 I completely agree it sounds like something more serious than a wheel bearing, when those go it's usually gradual and not all of a sudden, I would say try and get the car on a lift or some jacks and poke around under there, spin the wheel and try and zero in on where the noise is coming from, also with the car off the ground shake the wheel, make sure there's no play, that's usually a good sign of a bad wheel bearing. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 2, 2015 Author Share Posted February 2, 2015 You can see the video I did here Bad wheel bearing: Link to comment Share on other sites More sharing options...
aac0036 Posted February 2, 2015 Share Posted February 2, 2015 with the car off the ground shake the wheel, make sure there's no play, that's usually a good sign of a bad wheel bearing.This trick doesn't work on AWD cars... don't remember why though Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 2, 2015 Author Share Posted February 2, 2015 The FSM says to check for up and down play in the bearing seeing how the wheel was when I was moving I'm sure it has play it in, I think I'm going to head home tomorrow after work to start working on it I have no clue how easy or hard it's going to be removed. Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted February 3, 2015 I Donated Too Share Posted February 3, 2015 It's not that difficult to do... except it's cold. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 3, 2015 Author Share Posted February 3, 2015 It's already been done did it last night Link to comment Share on other sites More sharing options...
