taylormac1993 Posted May 14, 2015 Share Posted May 14, 2015 Throwing the nss code is pissing me off royally. I have tried to follow the wiring from this thread http://www.subaruoutback.org/forums/111-gen-1-1995-1999/37184-5spd-swap-1998-subaru-99-completed-having-one-last-wiring-issue-plz-help.html#/forumsite/20514/topics/37184 I took one side of the nss and grounded it, then took the other wire into pin 82 on the ecu connector. Is this wrong? Does the switch need power instead of a ground or what? Its all very confusing. Also instead of clipping the existing wire coming out of pin 82, i spliced into it. I will try clipping it next (so the nss is the only thing going into that pin). I did this because i figured the wire was dead weight, but didnt want to cut it just in case this didnt work. Does anyone have a complete pinout of the B84 connector? Link to comment Share on other sites More sharing options...
taylormac1993 Posted May 15, 2015 Author Share Posted May 15, 2015 Also when i say nss, im taliing about the one on the transmission. The only one that isnt the reverse lights... Is this right? Im at a total loss here Link to comment Share on other sites More sharing options...
86bratman Posted May 23, 2015 Share Posted May 23, 2015 You need to cut the wire from pin 82 and connect the one you ran. I did the same thing when I swapped my 97 last year. Cutting the wire fixed the problem. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 23, 2015 Share Posted May 23, 2015 4EAT to 5MT Swap Link Dump: http://www.surrealmirage.com/subaru/swap/electrical.html http://www.subaruoutback.org/forums/111-gen-1-1995-1999/37184-5spd-swap-1998-subaru-99-completed-having-one-last-wiring-issue-plz-help.html http://www.legacycentral.org/library/transmission/electronics.htm http://www.rs25.com/forums/f105/t86304-diy-auto-manual-swap.html http://legacygt.com/forums/showthread.php/auto-manual-transmission-swap-158323.html http://legacygt.com/forums/showthread.php/05wrx-5-spd-98-legacy-gt-wgn-auto-5spd-conversion-136840.html http://legacygt.com/forums/showthread.php/05wrx-5-spd-98-legacy-gt-wgn-auto-5spd-conversion-136840.html Link to comment Share on other sites More sharing options...
taylormac1993 Posted May 23, 2015 Author Share Posted May 23, 2015 I cut the wire so just the neutral tranny switch is run to the pin. Fixed it completely. After a few hundred miles, now im throwing a cyl 3 and 4 misfire... Almost had it running right haha Link to comment Share on other sites More sharing options...
Zues Marine Posted May 24, 2015 Share Posted May 24, 2015 you need to study more!! use the links in that dump, those are the only ones I used minus the FSM and everything went right on the first try Link to comment Share on other sites More sharing options...
taylormac1993 Posted May 25, 2015 Author Share Posted May 25, 2015 Well im confident i have it done now and the misfires are something else. Im warrantying the wires soon so maybe thatll fix it. Timings dead on, coil and plugs are brand new, so thats thenonly thing it could be unless i have a bad injector or a burnt valve. Link to comment Share on other sites More sharing options...
