kalectic Posted August 13, 2012 Share Posted August 13, 2012 My 08 legacy's radio turns on & off, the volume changes and also from radio to cd by itself. The display also goes on & off. I recently was driving and the radio turned on a volume 26 shaking the window. An auto repair shop called a salvage yard to check on a radio and was told this was a common request. The dealer said to buy new radio. Any help here is appreciated. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2012 Share Posted August 13, 2012 Clean the battery terminals. Could be some corrosion there causing a weak voltage signal. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted August 13, 2012 Share Posted August 13, 2012 Had a similar issue, just decided to swap out the unit with another one I got off the forums, no problems ever since. Link to comment Share on other sites More sharing options...
mrmegadeth Posted August 14, 2012 Share Posted August 14, 2012 Same thing here last year. Buy a new head unit. Link to comment Share on other sites More sharing options...
kalectic Posted August 15, 2012 Author Share Posted August 15, 2012 Same thing here last year. Buy a new head unit. Thanks for your help! I will look into a new unit. Any thoughts on the a/c display? Link to comment Share on other sites More sharing options...
Pako Posted August 15, 2012 Share Posted August 15, 2012 I had the same issue when I first got my '08. Took it to the dealer both times, and both times they swapped the head unit out. I have not had any issues since. And yes, it also affected the A/C display as well. Link to comment Share on other sites More sharing options...
kalectic Posted August 15, 2012 Author Share Posted August 15, 2012 I had the same issue when I first got my '08. Took it to the dealer both times, and both times they swapped the head unit out. I have not had any issues since. And yes, it also affected the A/C display as well. Link to comment Share on other sites More sharing options...
kalectic Posted August 15, 2012 Author Share Posted August 15, 2012 thank you! I wish Subaru would recall a bad radio as I am out of warranty. This happened once before and it just started working normally and problem is back again. Link to comment Share on other sites More sharing options...
jmon4200 Posted August 16, 2012 Share Posted August 16, 2012 I have an 05 legacy gt stereo w/ dual auto climate controls for sale. Not sure if they are exactly the same. If your interested just let me know. Link to comment Share on other sites More sharing options...
kalectic Posted August 21, 2012 Author Share Posted August 21, 2012 Thank you for the offer! I'm not sure I want to try any more Subaru radios and am putting up with mine as sometimes it actually works properly. Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted August 21, 2012 Share Posted August 21, 2012 gets expensive to go a route other than O.E.. JDM kit etc... Link to comment Share on other sites More sharing options...
brad_houck Posted August 21, 2012 Share Posted August 21, 2012 i read somewhere that the connector between the face plate and the actual unit can become loose and that causes this. this happened to me before very frequently and i removed the radio and separated the face plate to check that connector and made sure it was in securely and then re installed radio and it hasnt happened since. hope this helps. Link to comment Share on other sites More sharing options...
brad_houck Posted August 21, 2012 Share Posted August 21, 2012 heres the thread http://legacygt.com/forums/showthread.php/radio-display-fix-142191.html Link to comment Share on other sites More sharing options...
Tehnation Posted August 21, 2012 Share Posted August 21, 2012 car-part.com Link to comment Share on other sites More sharing options...
garageelegance Posted August 21, 2012 Share Posted August 21, 2012 check and clean interior fuse / Battery terminal. Mine did the same thing Link to comment Share on other sites More sharing options...
