slvrlegacygt Posted November 14, 2011 Share Posted November 14, 2011 Does anyone have the device to pair the tpms sensors to their car in the Poconos. I just bought new wheels and the light is starting to drive me crazy. Sent from my PG86100 using Tapatalk Link to comment Share on other sites More sharing options...
LouzGT Posted November 15, 2011 Share Posted November 15, 2011 What I did was I reset my ecu with my accessport and it solved the tpms problem. Try resetting the ecu see if that works Link to comment Share on other sites More sharing options...
slvrlegacygt Posted March 15, 2012 Author Share Posted March 15, 2012 I didn't realize I got a response but I bought new wheels and new sensors so I need to pair them to my car Sent from my PG86100 using Tapatalk Link to comment Share on other sites More sharing options...
Strizzy Posted March 15, 2012 Share Posted March 15, 2012 Subaru dealer using the SSM. No other way. My bad luck build Link to comment Share on other sites More sharing options...
slvrlegacygt Posted March 16, 2012 Author Share Posted March 16, 2012 That's not the only way Sent from my PG86100 using Tapatalk Link to comment Share on other sites More sharing options...
HoosierDaddy2 Posted March 16, 2012 Share Posted March 16, 2012 ^^^^ Enlighten us please . Thanks. Access port using what device to do the reset? Link to comment Share on other sites More sharing options...
Power6 Posted March 17, 2012 Share Posted March 17, 2012 Accessport can't help with TPMS You need the ATEQ TPMS Quickset tool. It can read and write TPMS IDs on Subarus. The Quickset tool is not the "whole solution" because it can only read your current set of TPMS IDs from the car, and write ones you have saved or manually enter. If you have a brand new set of tires with new TPMS, you need to figure out the IDs to enter them into the Quickset program. Here are some ways you might do this: 1.)Tire place might give you the IDs (TireRack does this) 2.)Dismount the tires and read the IDs 3.)Purchase another tool like the ATEQ VT30 and directly read the IDs 4.)Find a shop/person with the above and have them read the IDs and give them to you 5.)Have a Subie/Tire dealer "set" your TPMS, then use the Quickset to read those IDs later, then you will have them for next time. Once you know all the TPMS IDs you can swap wheels and tires at will and update your TPMS IDs with the Quickset. The Quickset is only really worth it if you have multiple tire/wheel sets, makes it easy to swap at home. If it is a one time thing all the tire shops can set TPMS these days. If you anyone is in the Boston area and need some TPMS help I have the Quickset and VT30. Link to comment Share on other sites More sharing options...
slvrlegacygt Posted March 17, 2012 Author Share Posted March 17, 2012 I was just about to post this http://img.tapatalk.com/4257540d-8333-a163.jpg I bought them from Tirerack and instead of spending 100 to use it one time. I figured I could find someone local. Instead I got a few unnecessary answers. Thank you to the people who did respond with informative answers Sent from my PG86100 using Tapatalk Link to comment Share on other sites More sharing options...
CapnJack Posted March 17, 2012 Share Posted March 17, 2012 Call around to dealers. They can pair them to your car and it shouldn't cost much more than $20. Another option, if you swap wheels back and forth a lot, is to purchase another TPMS computer module. They cost about $80. Have it programmed and swap out the module with the wheels. Saves you from having to go to the dealer twice a year if you run snow tires. Link to comment Share on other sites More sharing options...
farberio Posted March 18, 2012 Share Posted March 18, 2012 I was just about to post this I bought them from Tirerack and instead of spending 100 to use it one time. I figured I could find someone local. Instead I got a few unnecessary answers. Thank you to the people who did respond with informative answers Sent from my PG86100 using Tapatalk Some TPMS sensors will do the same action this device causes with a sudden drop in pressure. Its a bit more inconvenient but also a bit cheaper. However, you still need to put the car into its TPMS learn mode and I am not sure how to do that on a Subaru. Link to comment Share on other sites More sharing options...
Power6 Posted March 18, 2012 Share Posted March 18, 2012 ^^^That VT15 above might not work, certainly not alone all it does is activate the sensors. There are no tools I know of, other than the dealer SSM of course, to put the TPMS into "learn mode", though some of the more expensive tools a tire shop has might do it. The ATEQ Quickset is the cheapest tool that can set the IDs, but the TPMS IDs need to be read and saved or manually entered with it. I have the VT30 which is a step up from the VT15, it can activate the sensor, and also display the ID so it can be recorded and used with the Quickset. Link to comment Share on other sites More sharing options...
