Sheppyman21402 Posted May 9, 2013 Share Posted May 9, 2013 I have a 2.2L That needs rebuilding. I have a spun bearing and have it mostly broke down at this point. one more piston to pull then opening the block. So my question is what is the best way to go? New everything? Upgrading everything? This is a motor with 250K on it. I am in no rush and the money wont be a deciding factor. Looking for any input possible. Link to comment Share on other sites More sharing options...
monkeyposeur Posted May 10, 2013 Share Posted May 10, 2013 Cheapest option is swapping a replacement shortblock. But as you said money is no problem so buy a STi and swap everything over. Link to comment Share on other sites More sharing options...
snederhiser Posted May 10, 2013 Share Posted May 10, 2013 Hello; What bearing is spun? Steven. Link to comment Share on other sites More sharing options...
mungewell Posted May 10, 2013 Share Posted May 10, 2013 Are the heads/cams good? If you spun a bearing there is possibility of metal flakes in all the oil passages, so give everything a good clean. I'll just leave this here: [ame=http://www.youtube.com/watch?v=-gmtEQ1GpmA]Subaru STI Short Block Assembly - YouTube[/ame] Link to comment Share on other sites More sharing options...
jp233 Posted May 29, 2013 Share Posted May 29, 2013 it's all about what you want out of it. Want crazy power? STi. Want to get a good daily driver that doesn't cost an arm and a leg? Rebuild the EJ22E if able. You will need to measure the bore at that age, not just size but out-of-round and taper. If you lost a lot of bearing material then the crank and block need to be checked a lot. I found my EJ22E in good shape at 200K (it wasn't broken, just decided to rebuild it, long story), just got honed and re-ringed (yes, re-used the original pistons and rods!). Heads rebuilt locally, not too pricey, and it works great. You'd be amazed how long the N/A motors can last, unlike the turbo motors. Durability went out the door once the EJ22T was retired, due to easy power that can be made with a few hop-ups. Link to comment Share on other sites More sharing options...
