bihsoccer14 Posted July 19, 2011 Share Posted July 19, 2011 i need help on what to do i been reading you need to change coils injectors . it runs fine when you drive it but when its stopped it just idles weird Link to comment Share on other sites More sharing options...
bmx045 Posted July 19, 2011 Share Posted July 19, 2011 what exactly is the code that was read? Link to comment Share on other sites More sharing options...
charlie_sheen Posted July 20, 2011 Share Posted July 20, 2011 this will be fun... try hitting the airbox with a hammer. Link to comment Share on other sites More sharing options...
bmx045 Posted July 20, 2011 Share Posted July 20, 2011 No, those coil injectors are serious biddness. Link to comment Share on other sites More sharing options...
Lardo420 Posted July 20, 2011 Share Posted July 20, 2011 If you recently washed your car you must have gotten soap in your intercooler Link to comment Share on other sites More sharing options...
Max Capacity Posted July 20, 2011 Share Posted July 20, 2011 Welcome to the forum. Please tell us what code you got. We need more info before we can take this seriously. Be easy on the new guy, don't want to scare him away. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
charlie_sheen Posted July 21, 2011 Share Posted July 21, 2011 No, those coil injectors are serious biddness. CoilS* injectors Link to comment Share on other sites More sharing options...
king_j Posted July 21, 2011 Share Posted July 21, 2011 coil pack bolts onto the spark plug, this is a seperate unit from the injector. read: http://legacygt.com/forums/showthread.php/cylinder-misfires-bad-injectors-please-post-here-85099.html tell us what code you have. you are able to view the code if you have an 05. search. Link to comment Share on other sites More sharing options...
bihsoccer14 Posted July 21, 2011 Author Share Posted July 21, 2011 Pffe is the code Link to comment Share on other sites More sharing options...
bmx045 Posted July 21, 2011 Share Posted July 21, 2011 I went to this site called google.com and typed pffe check engine in and it came up with a thread that said this "I had the same problem, but I kept getting a "PFFE code along with a misfire on cylinder 3" I changed a plugs and replaced the coil pack for cylinder 3. the car runs good after that. the way I figured it out was that I swaped the coil pack from cylinder 3 to the cyl. 1 and found that the code gave me a misfire on cyl. 1... in other words the coil was the only bad thing." Link to comment Share on other sites More sharing options...
SSpeed Posted July 21, 2011 Share Posted July 21, 2011 Link to comment Share on other sites More sharing options...
bihsoccer14 Posted July 22, 2011 Author Share Posted July 22, 2011 thanks guys i have other questions about mods i dont know if you guys could help me out Link to comment Share on other sites More sharing options...
bmx045 Posted July 22, 2011 Share Posted July 22, 2011 Link to comment Share on other sites More sharing options...
Lardo420 Posted July 22, 2011 Share Posted July 22, 2011 he just got a 2009 Legacy GT what can he do to it Link to comment Share on other sites More sharing options...
bmx045 Posted July 22, 2011 Share Posted July 22, 2011 whatever you do don't get soap in the intercooler, it can errode the aluminum. Link to comment Share on other sites More sharing options...
charlie_sheen Posted July 23, 2011 Share Posted July 23, 2011 thanks guys i have other questions about mods i dont know if you guys could help me out Im sure we could...but do we want to? Link to comment Share on other sites More sharing options...
bihsoccer14 Posted July 24, 2011 Author Share Posted July 24, 2011 performance , i was looking at invidia down pipes do they fit to any aftermarket exhaust and whats best exhaust for rumble Link to comment Share on other sites More sharing options...
bmx045 Posted July 24, 2011 Share Posted July 24, 2011 All downpipes and exhausts that are made for your year car will fit whether you keep the stock dp or the stock catback, or vice versa. Link to comment Share on other sites More sharing options...
