apoole Posted January 4, 2012 Share Posted January 4, 2012 I have a 2006 Subaru Legacy GT with 105k miles. Receantly the seal in the turbo blew and Subaru states that the entire unit needs to be replaced costing anywhere from $1900-2300. However I have found a Tomioka Racing TD05-18G Turbo brand new off of subimods for $900. Can anyone offer some advice here? Yes I'm a noob to Subaru and the forum as well. Link to comment Share on other sites More sharing options...
Rutchard Posted January 4, 2012 Share Posted January 4, 2012 Probably better off asking in the 4th generation Legacy subforum http://legacygt.com/forums/forumdisplay.php/fourth-generation-legacy-2005-2009-10.html This is the 5th gen subforum for 2010+ Link to comment Share on other sites More sharing options...
sschmelcke Posted January 6, 2012 Share Posted January 6, 2012 you will need a tune, possible injectors and a fuel pump. plus depending on the housing it may not fit with the stock top mount. Link to comment Share on other sites More sharing options...
CRAZY KEN Posted January 10, 2012 Share Posted January 10, 2012 ...i.e. Never upgraded ECU Management of any sort - Cobb AP, open source, ect.!!! Then find a used VF40 (stock turbo) new or used...check forum members...there are a lot out their that upgraded their turbos and still have their VF40...buy new - it's well under $1000 ...or buy used in poor condition and have it rebuilt to factory specs. Do not go bigger...if you do not have means of tuning it or wanting to upgrading other supporting mods. CRAZY KEN I had a 2005 LGT - gone through 4 turbos (vf40, 18g, 20g, GT3076R) and two motors (stock and built motor 412whp)...the tranny is the same except for clutch and flywheel! Link to comment Share on other sites More sharing options...
halwith Posted January 10, 2012 Share Posted January 10, 2012 If it's just a seal ,and the turbo hasnt been completely smoked, maybe you can rebuild it. http://legacygt.com/forums/showthread.php/vf40-rebuild-kits-82226.html Link to comment Share on other sites More sharing options...
contractkiller Posted January 11, 2012 Share Posted January 11, 2012 I bolted up a TD05-18G to my 05 LGT and did no other mods (fuel pump, injectors) and haven't had any problems other than an overboost code. And that's only thrown if you get into high boost and can be fixed with a proper tune. Oh but you will (should) need to run an IP&T filtered oil feed line. $170 from www.infamousperformance.net As far as fitment, I needed to shave off a bit of the turbo heat shield to make room for the insulated oil feed line from Infamous. Other than that it works like a charm. 4k miles later with no problems. Sent from my iPhone using Tapatalk what did u mean when you said. it felt like i was driving a civic? did u mean the car felt like it was more dependable and it was getting better mpg's? Link to comment Share on other sites More sharing options...
CRAZY KEN Posted January 11, 2012 Share Posted January 11, 2012 ...true that! No argument there buddy, but for apoole (who sounds completely stock) ... it would be easier and less headaches to replace his vf40 with a new, used or rebuilt vf40! That's all, CK Link to comment Share on other sites More sharing options...
Chris GTO TT Posted January 11, 2012 Share Posted January 11, 2012 Ok i'll be the guy to do it ... http://legacygt.com/forums/showthread.php/turbo-failure-wiki-173358.html 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
scoobyscoodle Posted January 11, 2012 Share Posted January 11, 2012 ^hey crazy ken, between the 18g 20g and 3076 which was your favorite and why? Link to comment Share on other sites More sharing options...
CRAZY KEN Posted January 12, 2012 Share Posted January 12, 2012 >>>GT3076R with a straight pipe exhaust and 44mm ewg...is hell on wheels!!! 3rd gear leap in front of a lightly modded GT-R 4th gear a stand still 5th gear...bye - bye legacy ... it's the GT-R's time to shine...stock tranny - 5th gear too tall ...definitely needs another gear!!! The guy rolls down the window and says..."dude your car is fast!" ...and I say, "Dude, I love your car!" CRAZY KEN Link to comment Share on other sites More sharing options...
GrimmSpeed Posted January 12, 2012 Share Posted January 12, 2012 Another good option can be a used vf52 ( turbo from 09+ wrx). They are direct bolt on and won't require any fuel mods. You can still get close to 300hp with it. If you are going with larger turbo like an 18G you will need to get fuel mods ( injectors and fuel pump) to get any kind of good results. You can run it with stock fuel pump and injectors but will have to detune. Taras Link to comment Share on other sites More sharing options...
scoobyscoodle Posted January 13, 2012 Share Posted January 13, 2012 >>>GT3076R with a straight pipe exhaust and 44mm ewg...is hell on wheels!!! 3rd gear leap in front of a lightly modded GT-R 4th gear a stand still 5th gear...bye - bye legacy ... it's the GT-R's time to shine...stock tranny - 5th gear too tall ...definitely needs another gear!!! The guy rolls down the window and says..."dude your car is fast!" ...and I say, "Dude, I love your car!" CRAZY KEN That's quite an anecdote. I've heard there's quite an increase in boost threshold going from a 20g to gt30. In your opinion that hit was well worth it? Link to comment Share on other sites More sharing options...
